160 odd kw is pretty good for a Mk5 GTI
My bad. Still good for a MK6. My Mk6 GTI makes 161.6kw (just looked up my dyno graph from last year) and that's stage 2 tune from DNA Tuning, Eurojet 3" downpipe and Unitronic intake. See graph below.
Anywhere between 160-165kw at the wheels for a Mk5/Mk6 GTI is about all you will get with the stock turbo. When i took my car to the dyno, the dyno operator asked me what i thought the car would make - and i said between 160-165kw providing everything is healthy because i knew this was a realistic figure.
Have a flick through this dyno thread which has a lot of Mk5 and Mk6 GTI's in it. The Official VWGolf.Net Dyno Power Chart
Looking at your stage 1 vs stage 2, it appears you have picked up about 5-10kw through the mid-range along with some more torque. Your torque now peaks higher, but then drops off more than before which is why perhaps the car "feels" a little slower.
I just printed out both of your power runs, and did my best to overlay the results for you. Unfortunately a different scale was used on each graph, so ive done my best.
You can see you have lost 5-10kw down low (say below 2,500rpm), but then you have gained 5-10kw from about 3,000rpm - 5,500rpm. Above 5,500rpm there's no difference between stage 1 and stage 2 because the turbo is maxed out.
You have gained a decent chunk of torque from around 2,200rpm right through the rest of the rpm range.
Thanks Lucas.
I just went to an APR dealer, and we discussed my tune.
I can't really understand what he said, but sure he said that my tuner cannot give me stage 2 tune.
The tune I got from HPF, actually made my car shift not smoothly than stock, and had delay on 2-4 gear @2-3k rpm after he tested drive. That I was worried about that is a problem with my gearbox for months.
Then I got a really good deal with him, and I got ecu updated straight to stage 2.
Now the car is smooth af!
I'm going to do a dyno run next week and upload the graph.
Thank you guys. I should have went to the better one before.
The sticker is MAAAAAD!
