Results 1 to 6 of 6
Thread: Dyno recommendation in Perth?
    Feb 2009
    Melbourne, VIC
    Hi guys,
    Not sure if this would be the appropriate place.
    Can anyone recommend any dyno places in Perth and how much they cost roughly??
    You can pm me if you're not comfortable revealing the information here.
    I'm curious to see the output of my Jetta after the APR stage1 upgrade.
    I expect there should be at least a hint of something in the output that one could see to tell the difference between stock and the 98 program.
    cheers.
    p.s. did a search but some of that info is from 2 yrs ago.
    '09 Jetta 1.4 TSI 7spd DSG in Platinum Gray
    May 2009
    Perth, WA
    Here are a few places that have dyno's, the first 2 i been to with my old WRX:
    All Start Garage - Malaga - 9248 7433
    Maximum Motorsport - Malaga - 9249 744
    Tokyo Motorsport - Welshpool - 9358 2729
    MY11 Golf R - Rising Blue - 5DR - DSG - 19" Black OZ Ultralegerra - Leather - Sunroof - MDI - Euro Plates - Milltek Exhaust - Bluefin - SOLD
    MY11 Tiguan 147 TSI - DSG - Pepper Grey - Black Leather - RVC - MDI - BT
    Feb 2009
    Melbourne, VIC
    Thanks! will give them a call. Hoping there's no big difference between the knowledge/expertise required for wrx's and jetta's.
    Aug 2007
    Perth WA
    Let us know how you go - there have been a few attempts at setting up a Perth dyno day event but we've always had trouble finding somewhere that caters for the AWD eg R32.
    I rem going to somewhere in O'Connor once too, XSpeed I think, and when they got my car up on there, they couldn't tie it down and refused to run it (edit; I think they were set up for RWD for FWD, mine is not AWD-separate to comment above)
    Would be good to get a day going for this when it's not the middle of summer too!
    '04 BMP MkIV R32 #144
    search getnew
    May 2010
    Perth
    really if your just after a before and after run it doesnt matter where you go.
    I use allstar garage in Malaga, but beware it takes some time to get it setup on the dyno as its a hub dyno, my Bora did about what I expected so its pretty accurate IMHO.
    Not so good for Geoff though, as doesnt suit fast turnaround times for a dyno day.
    Most 4wd dyno's will spaz out with haldex, better to pull the fuse and run that way for the R32's
    Current: '04 Astra SRI Turbo - EDS IPF Flash, 3" TBE, Quaife LSD
    Previously: Bora 4mo, cams, coilovers, tune, exhaust, brembo's etc
    Mar 2008
    Canning Vale, WA
    I just got a Mk6 GTI so would be keen to see what it puts out atw in stock form.
    Would love to be kept in the mix if a dyno day is sorted.
    T Go
    MY11.5 Golf GTI | Bluefin Stage 2 | Pipercross Stage 2 Intake Pipe | AFE Pro 5R Filter | SPM Downpipe | VWR Sport Springs | H&R 22mm RSB | R LED Tail Lights
