DNA Tuning (Australia)
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: dump pipe vs turbo back
    Most of them just clamp up. No welding required.
    Jan 2010
    Sweet.
    what intake options are available? Apart from apr. it's nice but crazily expensive for a box.
    Point Cook, Vic
    Quote Originally Posted by alphabeatsco View Post
    Since I can't see a flange on that end. Does that mean it needs to be weld? I have gti mk6
    the mk6 GTI has a clamp like this connecting the factory DP to the rear exhaust section. It is re-used to mate the two.
    FOLLOW US ON FACEBOOK
    Sweet.
    Suggest you do a bit of research as there's a few out there. Already quite a lot of threads on this topic. VWR, Forge, APR/Carbonio, Viezu are some of the more common ones but bound to be others too.
    Jan 2010
    cool. thanks for the information.
    I have recently installed a dump pipe that bolted up to the standard cat back on my mk6 gti. About 3 weeks later I installed the custom cat back. I have a viezu tune.
    The car was defiantly fast with just the ipe but with the custom cat back it sounds better!
    Bw mke sure you use exhaust sealant even if the dump has v band clamps. Exhaust leaks are the worst.
    Feb 2008
    Auckland NZ
    Sweet.
    On the MK6 the APR carbonio is not just a box, it's of carbon fibre contruction which in its own right is expensive to start off with.
    Also it has an air filter in the "box". The Carbonio system also comes in two stages.
    Lastly carbon fibre also reflects heat and it less likely for heat soak
    What ever other Intakes you may look at, make sure the intake does not allow fuel trim to go over 10% or it will potentially be maxing out the injectors which can be a bad thing.
    Audi S4 (2001) - Imola Yellow
    Secret Project
