Results 1 to 7 of 7
Thread: Downpipe for Mk6 GTI
    Apr 2016
    Hi I have a 2012 GTI with BSR stage 1 tune, which gives plenty more punch to an already nice setup. Exhaust is stock as is the intake and filter. I'm seeking advice on whether a catted 3inch downpipe would work nicely with stock catback exhaust and BSR stage 1 tune? I like the quietness of the stock catback. A little more grumble would be ok, but I'm a older guy who leans toward a more refined, rather than a rorty sound. I'd appreciate input from those with more experience.
    Sent from my SM-G920I using Tapatalk
    Sep 2010
    Southern Highlands NSW
    A downpipe on a stock cat back gives off a nicer deeper note and makes dsg farts a lot more noticeable ... I don't know about bsr tunes but most other tunes will need an upgrade to stage 2 software as you may encounter a CEL with the down pipe installed
    Polo GTI
    T-Roc R
    Tiguan R
    Apr 2016
    Thanks for reply. BSR apparently do not have a stage 2 and anyway stage 1 and bit with downpipe is enough extra grunt for me, otherwise I'm upgrading brakes etc. What is that causes the CEL with a chsnge to a 3 inch downpipe? I'm not across this stuff but I hoped with a catted downpipe and O2 sensors connected up as per stock I might escape this issue?
    Sep 2009
    Redcliffe, Qld
    It's an oxygen sensor that triggers the CEL. You can get a spacer for this O2 Sensor Spacer - 42 Draft Designs
    MkVI Golf GTI
    Apr 2016
    Great thanks for the link. I'm starting to get the picture of how to go about it. Can anyone tell me if my CCZB engine has a different flange at the turbo from the CCTA and CBFA motors? I like to avoid ordering the wrong pipe.
    Quote Originally Posted by stevarm42 View Post
    They are all the same - as long as you buy a Mk6 GTI specific downpipe you will be fine.
    Apr 2016
    Great thanks mate
