Would ceramic coating on the DP help?
Magnaflow should be fine as long as its 200 cell metal inside.
The problem with the TSI downpipe & custom fab is a few things. 2.75 is the ideal size we are shooting for & its not super common, so some places don't keep it - secondly there are two heat shields that need to be fabricated onto the exhaust in the first section, there is a lot of wiring & coolant hoses running close to the upper section - not impossible, but very time consuming on one offs. We have also added extra heat protection where is passes under the intercooler return section & through the sump cavity. No use gaining horsepower if you add intake temps or shorten component life!
Sorry, I meant in addition to the 2ndary shielding - I'm paranoid about heat soak.
We are now 18 months down the track, has anyone seen a downpipe for the 118TSI yet?
Looks like Supersprint have one but it has no cat. 458 GBP.
I'll see if i can find anything else.
Supersprint Turbo Downpipe Kit, VW Golf MK6 5K , 1.4 TSI 160Hp 09 On Race Use Only
This ones for a Polo GTI 1.4TSI: Downpipe and race cat for a VW Polo 1.4 TSI 2010+ but it might also fit the Golf with the same engine?
^ Bugger - fair enough.
What about this one: VAGSG Community - View Single Post - Velocity downpipe for vw scirocco/golf/jetta 1.4 tsi
It doesnt have the heat shields but surely you could get an exhaust shop to help out with that when installing.
Or these (if you can read Greek)
Down pipe MAVROIDAKOS down pipe 1.4 tsi 160 | racing-exhaust.gr
Ragazzon Stainless Steel Down Pipe for Turbo - Replaces Catalyst (Part of a kit)
https://www.blueflameperformance.com...sport-cat.html
