Originally Posted by
DNA Tuning
Hi Brad,
It's almost as simple as what you've described; when you receive the SRS-II package, simply plug it into your OBD port; it will read your stock engine data and store it within itself.
The next step is that you will need to install the DNA software on a Windows PC and connect it to the SRS-II via supplied USB cable to copy the file from the SRS-II onto your computer which you send to us. The upgraded maps are transferred into your file and we send this upgraded program back to you.
This program is transferred onto the SRS-II again via USB cable, and then the SRS-II is now ready to upgrade your car. You can then switch back and forth without the use of the PC thereafter. The unit, once mated to your car, will identify your VIN and will only ever work with your car.
All instructions and everything you need (other than a Windows PC of course) is included in the package.
In line with current promotional price for the 2.0TFSI, the R32 upgrade software is $730, and $260 for the SRS-II unit including shipping which brings the total to $990.
Intake modified are fine as long as the MAF sensors are left unchanged, so in this case having an EVOMS intake will be totally fine.
If you would like to place an order please contact me, cheers.
