DNA Tuning (Australia)
Results 1 to 10 of 18
Thread: DIY Strut Brace
    Jul 2005
    Melbourne, Williamstown
    DIY Strut Brace
    Hey people,
    Have been looking around at strut braces and they seem to be very simple devices. Stiffening up the flexing vital geometry points of your suspension
    So simple in fact I'm seriously concidering making one myself for the rear towers. I'd make it out of proper chromoly bar.
    I remeber my first Mk1 had a straight bit of pipe flattened at both ends and bolted through the front of the wishbone points and it worked a treat.
    Has anyone made a strut brace themselves??
    mk2 GTi 16v
    Corrado G60
    Apr 2006
    Hobart,Tas
    I didn't bother with the upper rears in my comp golf. I spose it would tighten the body maybe but as far as suspension geometry the rear towers dont have a lot to do to keep the suspension from flexing. If you put rods with rosejoints from the lower shocker bolts to the beam, I think that would be better. However, you then have an exhaust clearance problem. The rear suspensions on a lot of competition golfs are gusseted to strengthen and to minimize flexing.
    However, when people drive RSI Beetles sideways into curbs as in targa a few years ago it makes repairs 200% harder!!! I am glad Paul Stokell got a good nights sleep that night!
    Definately the front can be improved with upper and lower braces. Well worth it
    Camden, Sydney
    On a Mk1, the bottom front is the most useful, then upper front. Upper rear does the least. Would be much the same on the Mk2, except they have better antirollbars as stock.
    Oct 2005
    Dandenong North, Vic
    I put an Eibach upper brace up front on my MK2, noticed improvement or slight difference in steering around corners at first but soon got used to it. Also put a rear Autotech on the top rear towers, no drilling was required, just a clamp type fitment with a centre adjuster. I had an annoying squeak or croak coming from the left hand rear trim up the back. Stopped that a liitle.
    Jul 2005
    Well I think I'll give it a go anyway, my neighbour is building a sports sedan and is excellent at Tig welding. I had planned on making my design for the upper rear brace on then Clamp Type with an adjuster and if it works out I'd do the same for the front and get some 5-10mm thick plates made for the towers(designed on solidworks) and then a few mandrel bends and a central adjuster.
    mk2 GTi 16v
    Corrado G60
    Oct 2005
    Are you drilling through the front towers or clamping ?
    The notes I got with the rear brace for installation was to be carefull when adjusting the centre adjustment as it could break the towers when tightening Some may have some rust on the towers. The only mod I had to do at the back was the rear side speaker shelf was in the way, just had to file away some plastic for the holder.
    Apr 2006
    Hobart,Tas
    With my front upper strut brace I added a third mounting bolt to top of the tower to stop "rocking" of the brace on the original two studs. I actually used a Mirage rear brace with very little modification.
    syncro Guest
    Better off not making the braces adjustable.
    Make the body fit the brace.
    Returning the body to factory specs makes a big difference.
    sydney
    here is the one i made for the rear,
    mounted and tensioned around the top of the turrets with u bolts
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
    can we please have a top view of the brace?
Similar Threads
  1. Mk2 strut mounts/bearings
    By aliasmk2 in forum Recommended Repairers and Parts Suppliers
    Last Post: 02-01-2007, 10:24 AM
  2. Strut Brace
    By PoloGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 28-10-2006, 11:10 PM
  3. Front Strut Brace
    By vee_dub in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 01-06-2006, 09:16 PM
