Results 1 to 3 of 3
Thread: Digifant II fuel system - convert to carb
    Tasmania - Hobart mainly
    Hi all,
    I converted my 1977 1600 GLS to an 1800 RV engine last year but kept the standard carb setup, luckily the manifold still fit.
    I say lucky because this particular engine has a fuel rail and injectors bolted to the head, i now am at the stage where they are possibly going to get in the way of a new manifold and carb i wish to install.
    It is a digifant injection system which was originally on there i believe, and i need to know if it is possible to permanently remove the injectors and somehow cover the holes they were in, but would this have an impact on pressure inside the head?
    Does anyone know if it is possible to do this successfully?
    If so, please could you provide some advice on what could be done.
    Thanks,
    Ross
    Camden, Sydney
    Yeah you can take out the injectors and plug the holes.
    You can either leave the plastic inserts and put a suitable bolt in there and screw it in.
    Or unscrew the plastic injector sleeves and turn up some blanks with a thread and screw em in.
    Thanks Golf Loon, thats excellent!
