DNA Tuning (Australia)
Results 1 to 2 of 2
Thread: Digi2 o2 sensor woes
    Jul 2005
    Newcastle, NSW
    So I am not the best yet with reading wiring diagrams, but the situation I have is...
    The MK1 has a MK2 digifant 2 loom in it with all of the connections to the devices being spliced on at the time the engine went in.
    I was going to install a wideband o2 gauge yesterday and simply could not get the right feeds (earth, 12v+, signal) from the wiring harness that led to the existing o2 sensor. More and more invetigation leads to me being a bit bewildered, so I decided best to trace back to the splice and start again.
    What I found were these...
    Brown/Black wire, Red/White wire and what looks to be a black thicker cable.
    So headed to the trusty Bentley and found the diagram.
    It says I should have a Brown/Black wire, Red/White wire and a Green signal wire.
    In this diagram it states there is a wire that intersects from the block to the Green signal wire, but I am really confused about this. From the diagram, is it simply spliced to it? Is there something going on that I am missing?
    Any advice appreciated.
    Jul 2005
    Newcastle, NSW
    Ok, so the deal is the signal wire is shielded and the earth is connected to the sheath. Learn something every day right!
