DNA Tuning (Australia)
Results 1 to 10 of 16
Thread: Difference between CAI and SRI
    Rads Guest
    howdy all
    My name is Rads and I am new to this so please be gentle and excuse my lack of knowledge.
    I currently have a stock 2005 VW Golf and wanted to do make minor modifications to it. I've got a bout $400 to spend so nothing major. I want to play around with the air filter/air box and I have read so much conflicting stuff on the net its actually frustrating.
    What I would like to know is;
    1) For my stock VW Golf would a CAI or SRI be best?
    or
    2) The pipes/tubes from a SRI kit modified to fit the stock airbox with a replacement drop in filter?
    In terms of running rich or lean, does a CAI or SRI play a part in that?
    Sorry if I am pushing my luck with my questions but i would really appreciate the advice.
    Thanks in advance
    Rads
    Aug 2007
    Perth, Australia
    welcome to the forums mate! this is the right place for asking these kind of questions and just generally wasting time at work
    I had a POD filter on my car and it caused the MAF to die. I have a CAI now, and i can't believe how much difference it made. I had a Liberty B4 before this and that had a CAI as well, and ran so much nicer. I'd spend that money on a good CAI.
    1991 BMW 318is RED E30
    Rads Guest
    Quote Originally Posted by balkanac View Post
    So you rekon a CAI ha? What CAI brand would you recommend i go for? Also, a CAI makes no difference if the car is not a turbo right?
    I was interested by the BMC-CDA filters because of the carbon fibre surrounding the filter. It makes sense to have set up like this dont you think?
    Feb 2007
    Bunyip, Victoria
    I have a BMC CDA, and it works very well. But it's very noisy. The extra response to the throttle is great. The extra top end is a good help too!
    Bloody expencive though.
    I'm not entirerly sure what an SRI is except a model of Holden Astra and Berina.
    Are there any off the shelf CAI kits for MK5?
    The only KIts i ever see are the SS inductions kits for holden and ford. Even K&N have a CAI kit for holden and ford!
    Rads Guest
    Quote Originally Posted by ScienceVR6 View Post
    They are damm expensive! Was it hard to instal in your car because if i end up buying a BMC-CDA, my car aint listed from the ebay seller so what i was thinking was to just buy one for another VW model and just work with that?
    A SRI is a Short Ram Intake.
    Rads Guest
    its me again...............could somebody please tell me if too much cold air is bad for the engine and would it have a negative effect on fuel consumption?
    Also, if i were to get a CAI and somehow managed to place the part with the filter on it in an airbox (completely covered), would that defeat the purpose of having a CAI in the first place?
    thanks in advance
    Feb 2007
    Bunyip, Victoria
    Quote Originally Posted by Rads View Post
    thanks in advance
    Don't worry what the e-bay seller says. Just get a mid sized one, and a heap of flexy tubing. Its gunna be a custom job. I'm using the standard plumbing from the trottle to the MAF. The maf in turn, is attached directly to the CDA. Air enters the CDA via the maf pipe from a LS1 V8.
    The one i bought was originally bought for a V6 commodroe, then it was sold to a bloke who wanted to fit it to his 5.7 commodore, but i wouln't fit in the engine bay, so i bought it.
    There is no such thing as too cold! Cold air is dense. Denser air means you can fit more in! NOS is a cooling and oxidizing agent. It cools the intake while oxidizing it to double or tripple the amount of cold air getting to the motor. I have seen Turbo and supercharged cars running water to air intercoolers, with dry ice in them. Intakes temps as low as -50c. Thats so cold that the air intakes sytem after the cooler was completly frozen with a thick layer of frost.
    Sep 2006
    Another option is to modify the standard airbox and feed cold air to it (do a search to find threads detailing the DIY). Then put a drop-in K&N filter and you will have as good an increase as a CDA, just with a stock look and for much less money. I have a spare K&N filter lying around somewhere if you are interested
    Jun 2006
    Orange NSW
    Nah, big gains from Atmo too dude. Colder air means colder charge, colder charge means denser charge, denser charge means more bang, more bang means more grunt.
    More grunt means more
    Rads Guest
    thanks for your comments people.
    I have read on forums and internet articles that by having a CAI or SRI will actually be worse in terms of fuel effeiciency.
    Something about more air being detected therefore compensating that with more fuel.
    Any truth to this or is it a load of crap?
    Thanks in advance
