DNA Tuning (Australia)
Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: cutting springs
  1. #51
    Apr 2006
    Hobart,Tas
    Yes, I agree with you but having springs reset often weekens them. We used to do that with the rally Lancers in the old days and they wouldn't last. Mind you, we could also fit new Bilsteins and springs in those things on a friday before a rally and on the monday we would have 3 Lancers back in the workshop with bent Bilstiens and broken springs!!!!.
    Its not that hard to raise the strut towers, takes about 3 hours plus extra to tidy them up, bog them and spray. Its just the initial cut that hurts!!!
    Next time I am up at my shed I will get some pics of the adjustable spring seats that I fitted to the the stock strut tubes. (Well, really Bilstien tubes but they were the same as the stoks externally. Cheers, Andrew
  2. #52
    Sep 2005
    Maroubra Beach
    anyone got any springs that are lower than 30mm drop that they want to get rid of?
    Or want to swap for some 30mm springs?
    i just want to go lower!
    2009 Volkswagen R36 Wagon
    1968 Audi F103 75L Coupe
    1966 Volkswagen Beetle Deluxe
  3. #53
    Apr 2006
    Hobart,Tas
    Watch out with too low a springs on std strut lengths. Read earlier in this topic, you will run out of travel very easily. beware!!!!
  4. #54
    Sep 2005
    Maroubra Beach
    Quote Originally Posted by gtimk5
    Yeah but i should be ok as i have adjustable shocks
  5. #55
    Apr 2006
    Hobart,Tas
    I will get some pics of gunters front strut setup this weekend because if you are going low you have to cut and gusset the rhf section above the driveshaft as it will foul the bodywork.
  6. #56
    Apr 2006
    Hobart,Tas
    Heres some pics of "Gunters" front spring setup. The struts originally had the std size seats but we remonved then and fitted some threaded seats, available at "race type shops". Note that just behind the brake pipe I have cut out and gusseted the inner guard section to give the driveshaft clearance. You must do this if you are going low and driving around the roads or tracks.
    Hey! Its no show pony but I achieved remarkable results with Gunter!!!! And that would be THE hardest 23,000 kms that a golf could get I reckon!!!
    Cheers, Andrew
  7. #57
    Gosford Central Coast NSW
    those struts are great on gunther mate, i like very much - seems like ideal for long travel but low ride.
    once again on the cutting issue, with respect to rust - any decently manufactured spring wont rust - the steels metallurgy will likely prevent seriuous corrosion past some surface flecks... in any case, repainting the ends can be done.
    i have to say that im not an advocate of cutting..... but i've done it on my diesel, and i'll tell you a little story...
    sonce cutting my king springs (already lowering springs, but not much) i've done about 10,000 km's - all this year. just last weekend, i went from newcastle/hillston and back, on some very bumpy, hollowy roads, mosly pushing along at 120 (yes, my diesel can do that)
    did i bottom out? yep, sure..... but the rear, not the front. my lip spoiler, which sits 80mm from the ground when the car is stationary, didnt hit the ground once.... i had 3 big guys and a lot of luggage in the car. i had rear tyres botomming on the insides of the guards (rear springs are also king lowering springs, but they are not cut).
    so heres what i say: if you wanna cut your springs, you need to be careful, adn think about it.
    you wouldnt cut your stockies off to drop the car a couple of inches, because thats dangerous..... (unless you want a set of show only springs, hehe) but if you have some harder springs, maybe you might take off half a coil, or afull one, to get the ride height just so...
    and ofcourse, if you can afford it, treat yourself to coilovers.
    if you want a 2.5 inch drop and you cant afford coilovers, then i think everyone would agree you might just have to wait a bit, and save up.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
Similar Threads
  1. VW Mk1 Track Car Springs?
    By luke_how in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 21-10-2006, 11:37 AM
