Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Cupra Leon 2024 (Spanish Golf Mk8 ?) Fault Code dramas
    Jul 2024
    Unhappy Cupra Leon 2024 (Spanish Golf Mk8 ?) Fault Code dramas
    Now sorted : See latest post.
    Hi all,
    Hopefully this is the best place to put this cry for help.
    Recently purchased new, a 2024 Cupra Leon V (140kW/320Nm) Spanish Golf. See Newbie thread here >> 1st time VW owner, well, Spanish Golf !
    Car is great apart from not having the better brakes (same as Golf 'Performance Pack system), so got a set from a Golf R Mk7 and did the swap with new pads and rotors. Great.
    Problem was, I inadvertently damaged the LH rear wheel speed sensor (sensor tip damaged - long story) and of course, a host of warning bells and whistles.
    Finally got a replacement on Friday, and along with the Carista, tried to reset the multitude of fault codes with some inner hope being strong.
    But, sadly, the result was far from good.
    Some codes cleared and some wouldn't. Tried ignition off/on and clear codes (several times) and even fully disconnected battery for 10 minutes and tried again. Same response. Took it for a drive and repeated above steps and no change
    Download from Carista here (maybe a reset of some sort is needed ?)
    CAN network gateway:
    2175091 - Information electronics control module 1: No communication
    2498675 - Ethernet Information Electronics Control Module 1: no communication
    3145728 - Data bus: Additional installations detected
    8471816 - Databus error value received
    Engine:
    23410 - Invalid Data Received From: Anti-Lock Brake System Control Module
    23765 - Information electronics control module 1: No communication
    ABS:
    16390 - Tire Pressure Monitoring System (TPMS): Signal malfunction
    197968 - Left Rear Wheel Speed Sensor Circuit/Open
    198224 - Left rear ABS wheel speed sensor: Incorrect component installed
    00294 - Steering angle sensor: no initialization
    08563 - Power Steering Control Module: Implausible signal
    08796 - Invalid Data Received From Chassis Control Module "A"
    Power steering:
    01362 - Databus error value received
    05423 - Steering angle sensor: no initialization
    Airbags:
    1050117 - Databus error value received
    1052934 - Databus error value received
    1075461 - Databus error value received
    1075462 - Databus error value received
    1075463 - Databus error value received
    1075465 - Databus error value received
    Parking/steering assist:
    13637203 - Databus error value received
    13637409 - Databus error value received
    13637426 - Databus error value received
    13647889 - Databus error value received
    13688835 - Databus error value received
    Suspension:
    7340038 - Databus error value received
    Central electronics:
    337928 - Databus error value received
    Driver's door:
    196660 - Window regulator motor: no basic setting
    Front passenger's door:
    Adaptive cruise control:
    02055 - Databus implausible message
    209153 - Databus error value received
    02101 - Databus error value received
    02425 - Databus implausible message
    00567 - Databus error value received
    00577 - Databus error value received
    00723 - Databus error value received
    00790 - Databus implausible message
    00800 - Databus error value received
    00815 - Databus error value received
    00863 - Databus implausible message
    Lane-change system:
    2236417 - Databus implausible message
    2236426 - Databus implausible message
    2236437 - Databus error value received
    2240519 - Databus error value received
    2240523 - Databus error value received
    2252891 - Databus error value received
    Back-up camera:
    13705989 - Databus error value received
    13706006 - Databus error value received
    13706016 - Databus error value received
    Driver assist front sensor:
    1123173 - Databus error value received
    1126450 - Databus error value received
    1126466 - Databus error value received
    1126472 - Databus error value received
    Steering column lock:
    13637378 - Databus error value received
    13637386 - Databus error value received
    Light control 2 (left):
    131376 - Databus error value received
    Light control 2 (right):
    Why did I start ......
    Anyway, any suggestions from anyone ?
    Only other though is somehow damaged the harness at the rear ?
    If I can't find any obvious issues, who in Adelaide is recommended workshop to take it to for some detailed advice ?
    Hi Michael,
    Not sure what is going on, but can understand you are annoyed with the issues on a brand new car!
    Sounds to me like one of the following scenarios:
    - Damage to another area of the wiring/plugs
    - Incompatible wiring/plugs/sensor due to the change in brake calipers and disks (possible that your wheel speed sensor is not compatible with the larger disks/calipers?)
    Was this scan taken after reconnecting the battery, taking the car for a drive (making sure to turn steering wheel full left and full right to calibrate the steering angle sensor) ?? Im pretty sure a good amount of these errors should go away after a short drive.
    Jul 2024
    Hi Michael,
    Hi Lucas, Cheers for the reply.
    I think, wiring damage is the most likely option, but hard to fathom where and how. Nothing was touched under the bonnet (apart from brake res top up). Maybe when changing the caliper ?
    Wheel speed sensor - same one was put in. Got the part number from the part I broke and also from an EPC (7Zap - but can't get back into it ??) for the current model Formentor with the same brakes. Will have a closer look at the sensor and how it fits in and measures any input to see if that is a potential issue.
    Didn't do the full left/right on the steering wheel, so will try that again. Prior to that, will have yet another look at each of the plugs and the wiring that I removed/reconnected to see if I can see anything. A pain without a hoist, but I'll manage.
    The curious thing is I looked on the web at several sites showing the swap to the PP brakes on Golf's and assumed that it was essentially the same as basically it's the same chassis.
    Hmmmmm
    Jul 2024
    A bit more digging, and I think I may have found a potential answer ....
    Of the Golf Mk7 R donor parts, the only part that wasn't compatible was the rear dust shields. The VW ones could be slipped on over the rear hubs and held on with 3 bolts. The Cupra ones were mounted such that they are bolted on BEFORE the hub is fitted.
    In order to get the bigger rotors to fit, I had to cut/mangle the original dust shields off, and I probably damaged the integrated sensor ring whilst doing so, not even knowing it was there
    Seems like it's a solid possibility that I need new Rear L&R hubs - here Just a moment... or here 2006-2024 Volkswagen Hub & Bearing 5Q0-598-611 | OEM Parts Online
    Likely part number 5Q0598611. On a large number of cars, so may be able to find a 2nd hand pair at a reasonable price.
    Only reason I didn't taken them off properly, as I didn't have the tool to remove the hub nut. Too much of a rush.
    If I was going down that route, I'd get the proper fitting rear dust shields too, as they are not expensive, but can't find the EPC that I did before, Grr
    Something to investigate over the weekend !
    Definitely could be the main issue.
    Jul 2024
    Hmm, more digging done and consulting with 7zap (Seat Parts catalog - ETKA Online, seat EUROPA, original Catalog seat EUROPA), the dust shields for the rear show this image ;
    Cupra Leon 2024 (Spanish Golf Mk8 ?) Fault Code dramas-rear-disc-dust-shield-310x22mm-jpg
    where the format of the dust shield is such that it clearly shows that it goes on before the stub.
    The part numbers identified are 5Q0615611S/5Q0615612S (Left/Right).
    Then a I find someone in Adelaide with a pair (from Audi RS3) clearly marked with these same numbers, the image are ones that slip over the stub axle ?
    Audi RS3 RSQ3 Pair of 310mm Rear Brake Dust Shields 5Q0615611S 5Q06156
    – VDL Adelaide Spare Parts Store
    The ones that I got from the Golf Mk 7 looked like these, but the 3 mounting bolt holes did not align !
    Mega confused. Will contact the supplier (as local which is amazing) as may be able to get the stub axles as well.
    Jul 2024
    Got the correct part number hubs from the local VW dealer, so ordered replacement hubs from Spareto in Lithuania for a grand total of $250 vs Genuine parts that would be $1,360.
    The replacement ones from Spareto are SKF VKBA 3656. Could have got them from Run Auto, but their price was $340 delivered.
    Just FYI for any future Cupra related threads, there is now a Cupra section on the forum: https://www.vwwatercooled.com.au/forums/f257/
    Quote Originally Posted by Michael_B View Post
    Honestly the Run Auto Parts price is decent in my opinion. You have to weigh up cost vs how long they will take to arrive. Whats the timeframe for Spareto?
    Jul 2024
    Noted.
    I saw it the other day
