I'll jump in here and answer that for you, i was there for the entire process while the tunes were being tested. The car (jimjaroos) was run with the APR tune to gain the data shown. The car was then taken to an APR dealer to have the tune removed and taken back to BPS to be dyno'd to get the VW base run.
Right after the base run was completed the ECU was removed and James commenced to apply the BPS tune, then the car was dyno'd right after that to produce the BPS result you see on the graphs. It was all above board, completely fair and legit.. he wasn't employing any 'manipulation' or tactics as earlier suggested.. unless he was very sneaky about it!
I don't think this is about trying to tarnish the name of APR, i think it's more to demonstrate it isn't necessarily the 'best' and there are most certainly alternatives available to gain a fantastic tune on the R. I drove the APR tune and i personally think it was designed to give you that surge when the boost came on which makes it feel quite fast.
I drove the BPS tune last night and as a comparison you don't feel a rush like the APR, the delivery is very linear and seems to progress very smoothly across the entire range! Was really quite impressive, but coming from an R34 GTR background i am also quite a fan of the 'surge' feeling that you get from boost coming on hard
