Results 1 to 6 of 6
Thread: Cold Air Intake (with MAF sensor)
    midget Guest
    Hey Everyone
    Just seeing if anyone else has installed any type of cold air intake system into their Car whilst still having a MAF sensor plugged in?
    Did you just get an adapter bracket so you could fit a pod on the end?
    Camden, Sydney
    I`ve used a few on VR6s which have a similar MAF setup to your car.
    You need to take the section of intake plastic out that contains the MAF sensor. It has a funny shaped end which you need to transform into a circle. Either make up an adaptor plate, or grind it down so that you can stick a Sport type filter on the end.
    Makes a nice induction noise
    midget Guest
    Cheers Loon
    Yeah the idea is to attach pod filter with heat shield on the end of the maf then a flexi tube going down to the grill/fender
    yeah grabbed a converter plate this afternoon from supercheap
    http://img37.imagevenue.com/img.php?..._122_474lo.JPG
    probably gonna grab the other parts and fit tomorrow if its not raining
    do you reccomend propping up the MAF? as it is quite weighty, a couple of brackets will do fine i guess?
    Camden, Sydney
    Sounds like you are into it.
    Couple of brackets for neatness.
    midget Guest
    a couple of hiccups
    ok
    she starts but wont idle and you have to keep your foot on the pedal to keep it running.
    so a couple of questions (apologies for the noobishness)
    these are just camera pics and are a bit grainy
    the vacuum pipe http://xs.to/xs.php?f=DSC00246.JPG&h=xs308&d=06422 , am i supposed to block it up? or leave it as is?
    this is a pipe that originally ran into the side of the airbox http://xs.to/xs.php?f=DSC00247.JPG&h=xs308&d=06422
    anything need to be done about this?
    and here is the buttom half of the airbox just so you know what other components there were.
    any insight as to what i may need to do to get this working would be much appreciated, as im sure other ppl have had similar/same probs
    midget Guest
    Bumpity Bump Bump
    Hellpppp
Similar Threads
  1. ABF cold start
    By golf3 in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 10-02-2007, 08:26 AM
  2. Outside air temp sensor MK2 GTI
    By aussieg60 in forum Mk2 Golf & Jetta
    Last Post: 15-02-2006, 04:13 PM
