Shrouded injectors
Hey pete,
Have modified my 1600 injection system to run with the 1800 air shrouded injector head.
From what i have read and heard, the air shrouding helps to insulate and cool the injector from the heat present in the head ( the earlier unshrouded injectors use to suffer from hot start problems, heat build up after turning the engine off would boil the fuel in the injector and lines, making hot starts difficult at times, usually on days with high ambient temps, would require bleeding the injectors of vapour till they started squirting juice again )
The head i am using has a metal pipe pressed into the head *( as opposed to your bolt on plastic fitting) I ran a hose from here to a tube silver soldered onto the metal air pipe that goes from the throttle body rubber bellows to the auxillaury air valve, this way the injectors always recieve air around them ( air supply after the fuel distributor plate, but before the throttle butterflies) and doesnt upset the idle speed or the mixture setting of the fuel distributor.
Good to hear your changing all the seals ( inc the insulator seat seals and insulators) I used these buggers...
http://www.techtonicstuning.com/show...artnum=133.341
HTH..
Lots of MK 1 Scirocco's...
Cheers,
Grant...
