DNA Tuning (Australia)
Results 1 to 6 of 6
Thread: Chipped? Check VIN?
    Sep 2009
    Chipped? Check VIN?
    Apart from the seat-o-the-pantsometer, how can I find out if my car I bought 2nd hand has been chipped? I have driven a few GTI's but not sure how big a diff the common flashes make.
    If I contact the local distributor for each chip/re-map and tell them my VIN will they be able to search a database to see if my car has been done?
    I am looking at reflash for a mk 5 GTI with the usual suspects of GIAC, APR. Is it really obvious diff to standard?
    Point Cook, Vic
    get someone with a vagcom to log the boost.
    Can you wheelspin right through second gear if you try?
    FOLLOW US ON FACEBOOK
    Aug 2009
    Melbourne, Vic
    You may be able to spot an APR reflash by seeing if you can switch it on/off via Crz Control. Procedure detailed at APR website. Essentially with IGN On, ENG OFF & CRZ CNTRL ON hold the SET button down and see if anything happens with Check Engine Llight on your dash after 5 secs..
    Apr 2006
    Hobart,Tas
    You may only find this if the vehicle isnt fitted with the security lock out pin code.
    If you send us the VIN & also check in the owners handbook for the original owners name & email it to us we can try to check against our database for you. We have almost 1200 MKV's on there, can not guarantee it it, but will do our best for you.
