From the look of the photo, it looks like bits of impeller have impacted the other impeller blades quite a lot..... probably the impeller casting is not up to scratch (because of the way it is broken in different places on every blade) but i think the problem probably originally arose from the bearing - if there was so much play to allow the shaft to move that far from side to side (look closely you can see how the impeller has worn away to the contour of the inducer on the sides).
I'm curous - why did it take 60km's to stop driving? It must have been howling something feirce with the impeller touching the inducer - I know i've heard it before myself!
ALSO FYI to anyone - its very easy to put a chinese made turbine wheel, compressor wheel and bearing set into genuine KKK housings - there's no way to tell the difference, as Preeny has pointed out (apart from maybe "excessive" shaft play, but even genuine turbo's can have enough shaft play to allow one of the wheels to contact the housing if you push it to the side, depending on the turbo)
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
