Check that the MAF is not backwards. When you pull it out you can see the window that the air needs to enter into. US spec GTIs have the orientation of the screws reversed.
If thats ok check that you dont have any leaks.
Just installed awe tuning intake on the mk6. When I start the car, it starts then the idle goes crazy... Up and down ... Really rough... What can be wrong? I tried vagcom, no fault codes
Thanks Tim indeed it was backwards... It's fixed now...
what if you drive in reverse ?
Weird question... Is it normal that the car can't pass 4000rpm when it's in neutral and parked?
Normal on other cars. If it's an auto it's usually to stop you from neutral bombing it.
Sent from my HTC Velocity 4G using Tapatalk 2
VWWC Members - 2018 Special - ECU & DSG Remaps
DNA Tuning Australia - Enquiries: info@dnatuning.com.au
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
