DNA Tuning (Australia)
Results 1 to 9 of 9
Thread: Cars idle goes crazy after intake install
    Jan 2010
    Just installed awe tuning intake on the mk6. When I start the car, it starts then the idle goes crazy... Up and down ... Really rough... What can be wrong? I tried vagcom, no fault codes
    Point Cook, Vic
    Check that the MAF is not backwards. When you pull it out you can see the window that the air needs to enter into. US spec GTIs have the orientation of the screws reversed.
    If thats ok check that you dont have any leaks.
    FOLLOW US ON FACEBOOK
    Jan 2010
    Thanks Tim indeed it was backwards... It's fixed now...
    Jan 2010
    Weird question... Is it normal that the car can't pass 4000rpm when it's in neutral and parked?
    Jan 2009
    brisbane queensland
    Quote Originally Posted by parso_rex View Post
    what if you drive in reverse ?
    Lol lol lol
    YAY I got my R!!!! White, recaro seats, 19" wheels, bluetooth, reverse camera
    Jan 2013
    Re: Cars idle goes crazy after intake install
    Normal on other cars. If it's an auto it's usually to stop you from neutral bombing it.
    Sent from my HTC Velocity 4G using Tapatalk 2
    Sep 2010
    Melbourne, Victoria
    Sounds plausible; the exhaust becomes the intake and vice versa.
    Bowral, NSW
    Quote Originally Posted by alphabeatsco View Post
    My diesel won't pass 2,500rpm unless the clutch is nearly out and its in gear... Its a TC thing (and launch control? yay!)
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
