![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Grunmk1
My mate that used what I'm pretty sure was an SU for his draw thru turbo buggy had one issue - the SU didn't have any pump jets. They are extremely simple to tune and they have like one main tapered needle but the one he used didn't have an acclelerator pump jet which is crap when you boot it suddenly. It kind of slowly builds revs unlike webers which tromp like mad as soon as you stand on them.
SU's don't use a pump jet, they have a unique method of enriching the mixture when you boot it.
Inside the bell at the top of the carby there is a sliding piston which has a very light spring that pushes it down. When the throttle is opened, the venturi effect makes the piston slide up opening the port to allow the air to flow through. The piston has a damper which slows the initial movement causing the mixture to become momentarily rich. The damper requires a small amount of oil to be poured into the dashpot at the top of the carby from time to time and if the dashpot is dry, the piston will open fully immediately the throttle is opened causing the mixture to lean out and the engine to splutter.
See there is no limit to the information you can find on this forum! ![Biggrin](https://www.vwwatercooled.com.au/forums/images/smilies/biggrin.png)
George
06 Jetta 2.0TFSI Killed by a Lexus!
09 Eos 2.0TSI DSG Loved this car but has now gone to a new home!!
14 EOS 2.0 TSI has arrived!
