I have tried various different cam grinds over the years and it all depends on what your after power band and drivabilty wise. In a 1.6 litre the best factory cam is a "E" grind from the first series 1.6 GTI engines with the heron style head which is flat and dosn't have any combustion chambers in the head. They give a little more top end than a "G" grind from later 1.8 litre engines but still have a good torque band in the low rpm. The shim clearances can be adjusted yourself if you have a selection of shims and feeler gauges. With the engine cold the clearance between the inlet cam lobe and shim is 0.25mm to 0.35mm and the exhaust is 0.30mm to 0.40mm. The autotech 260 is a great all round cam for street and will give more power than both "E" and "G" grind factory cams. You can use your original valve springs they slip straight in as well. Schrick and tectonics are my pick for cam manufacturers. The best cam i have used would be the schrick 272 (big $) and this does require some die grinding to give clearance in the head due to the extra lift. Combined with 40mm twin webbers, 42mm inlet, 35mm exaust valves heavy duty valve springs and massive porting it totally transformed performance making strong power to 7500rpm. 160+ hp![]()
