DNA Tuning (Australia)
Results 1 to 8 of 8
Thread: Cam Shaft vs Cam Gears
    Dec 2006
    Hey guys just wondering what should be done first adjustable cam gears or different cams? From previous exp with turbo cars i thought it was the cam gears are a greater benefit but would lov to know either way. Btw i have a 2006 POLO Gti
    Only done both in one go but provided economy isn't a priority cam gear advanced works
    Both i'd say as fitting each involves removing the cams anyway.
    On a VW even though it has 2 cams, one is driven from the other by chain, so to alter the timing is a real time consumer.
    Nov 2006
    IMO you're better out maxing out the standard turbo (chip, intake, exhaust, fmic, turbo intake pipe) or getting a bigger turbo (Ko4 or above) than messing with your cams.
    You'll need to tune it to suit (aftermarket ECU - $$$ and pain in the ass) or use a tune available from APR/GIAC that suits the cams you buy (Difficult, rare).
    By all means, get some cams/cam gears, but after you've used other methods to get more power cheaper.
    Quote Originally Posted by jasn78 View Post
    As said above, I'd do both at the same time. You'll save yourself a truck load in labour costs.
    What else has been done to the car? If your considering this I imagine there is alot of other little gizmos that have been done too.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    IMO you'd be crazy to spend money on a set of cam's & cam gear's on a 20VT unless your going with a turbo sizing GT3076R & greater.
    The standard cam's an run upto & over 400 hp very easily & in some cases if the setup is right & the tune is spot on 500hp.
    I'd seriously spend the money on other upgrades, such as a CAI, front mount intercooler, larger turbo (GT2871R), remap, injector's etc.
    Cam's replacement is only really necessery when chasing big power with a big turbo, high air flow rate/volume & cyl pressure's. eg. As a very general rule, turbocharged gasoline engines will generate 9.5-
    10.5 horsepower (as measured at the flywheel) for each lb/min of airflow. So, an engine with a target peak
    horsepower of 400 Hp will require 36-44 lb/min of airflow to achieve that target.
    The standard cam's have an excellent spec. to chase nice power with a matching torque curve & a very broad power band.
    Ask bugracer (seb) & I'm sure he will agree, as he has built an approx 400hp 1.8T with standard cam's.
    Dec 2006
    Thanks guys just coming from a skyline background cam gears where always a way to get power after all your intake mods which apart from the dump pipe and high flow cat is where im at. So thank u all for ur help
    Jun 2006
    Orange NSW
    Glad to see you finally saw the light... And moved away from the japanese commodores.
