Something like a kent or piper fast road cam around 260/266 deg should be fine.
can anyone recommend a cam for a 1.8 GTI engine running injection.
nothing wild
what bout a nice wild cam for a carby 1.6 Mk1 motor.... ne suggestions? prices?
http://www.pipercams.co.uk/
I reckon you can go with a 285 on there myself... Depends on the carbs as to whether it's worth it? Better to go with injection IMO, more flexible economical etc. Makes me sound like a grown up but the truth always hurts..
nah i think ill stick with carbs myself. im gunna see if i can chuck on the 41mm bouble barrel webber ive got. yeh ill ask the guys at volkspower to see what they say. it should be worth itlong term is to drop a 2L 16v in there
Remember that you're limited to what your motor can safely withstand rpm wise. No point throwing in a massive cam if it needs 8000rpm for peak VE and you can only pull 6,500 without sending a rod through the block![]()
yeh i know.. i got my twin delortoes that i gotta bolt on. the boys at volkspower will recommend the right cam for the job![]()
