make sure its a bolt in![]()
hey guys anybody running a cage in their road car ? i have to get my mk2vr6 engineered anyway i was wondering if i can get a cage thru aswell ?
prob half cage for the street maybe i can get the rear seats taken out and rego as a 2 seater. any body have any experience doing it above board ?
cheers brenton
MK1 4door
MK2VR6
MK3VR6
Transporter
and untold wrecks
As forementioned, it has to be bolt in (thus completely removable).
Another important thing to consider is the it cannot exceed 5 points for street legal use. Finally, it requires an engineers certificate and a mod plate as well for it to be legal to use. With all that say and done, insurace wont touch you with a 20foot pole unless it's someone like Just Car...
GTI|BBS|Forge|Whiteline|Custom CAI+K&N|Sparco|Toyo|Martini|JVC|Focal|ScanGaugeII
If you plan on racing the car you need to make sure it's CAMS legal too.
Here's the CAMS regs http://www.camsmanual.com.au/pdf/gen...ule_J_Q208.pdf
I'm told it can be tricky to build a cage which is both CAMS and street legal.
I'd suggest you get an engineering firm to manage the whole project from start to finish so you can be sure it's safe and compliant.
Pete
If you liked that, the rest of the CAMS manual has it's own website here http://www.camsmanual.com.au/general.asp
I'm told there's a program to make the thing simpler but fir the moment it's a confusing document to figure out.
Pete
I am also doing a half cage in my car. I understand QLD requires mod plates and so forth, but we don't have that kind of thing in vic. Will i still neeed an engineers cert for a bolt in half cage in vic? by 5 point, are you refering to having 5 points where the cage is mounted to the floor?
Vicroads info here http://www.vicroads.vic.gov.au/NR/rd...65/0/VSI28.pdf
Other useful Vicroads info here http://www.vicroads.vic.gov.au/Home/...dsInformation/
Pete
Its BS a proper CAMS log booked cage does not pass a RWC in Vic due to the side intrusion bars and the a pillar bar...
Its a load of crap a side intrusion bar will save your life but wont pass a RWC![]()
