nice one pete... just did a serp setup on my mk1 engine too.. did it differently to you, but ill post up here when its finished to add to the knowledge base!
love your work!
mike
love your work!
mike
TDI mk1 on the road!!
you used a drill as a boring bar!!!!horrified doesnt even cover it
nice work mate![]()
The drill bit wasn't used for this job, it was there from something I did previously, it was the tool I was reffering toThat one has a triangular tip which isn't so good for parting off. I changed to a parting off tool after this photo.
Maybe you should bring me up to speed on the basics one day.
Pete
Nice write up Pete. I have the same setup in the Caddy and your accurate belt measuring could have saved me 3 trips to Bursons!
Nice work Pete! Great to see some mods like this so well documented. I to have done the conversion but took the easy way and bought a set of three alloy pulleys off ebay motors USA for $65 plus shipping. You need a carbide inserted face grooving tool for sure!
I see what you mean, a quick search came up with these couple of items.
http://cgi.ebay.com/ebaymotors/VW-Go...ayphotohosting
Addicted2Racing
This auction is for a BRAND NEW LIGHT WEIGHT BILLET ALUMINUM 3 PIECE PULLEY KIT (Exact weight 1.3lbs). Perfect Replacement for Factory Crank, Power Steering, Alternator Pulley. Fits Volkswagen Golf/Jetta 1.8T Turbo DOHC 20V & 2.0L SOHC 8V 99.5-03.
- Strong light weight billet T6061 aluminum
- Grade A+ quality
- Weighs less then 1 lbs per pulley, total exact weight is 1.3 lbs
- Revs faster and accelerate your car faster
- 3x pulleys included
- Direct Bolt on, Installation Instructions and Belt Size available (please seek professionals if you need help)
- Will need to replace old belt
And this little Gem which would simply replace the a/c compressor in a stock setup.
http://cgi.ebay.com/ebaymotors/NEW-A...ayphotohosting
There's a range of underdrive pulleys too, but I'd only run those in constant high RPM applications like a dedicated race car. Would need to put some thought into water pump rpm and cavitation issues.
Pete
Thats the pulleys Pete! Great buy dont you think, they are very nicely machined and a perfect fit.
Could you not go with the MK3 alternator setup? I'm about to do this on my MK2 1.8 gti but need a crank pulley (and Ideally a ramp!). The aleternator sits on a bracket that comes off the waterpump bracket. There's a link on Ed 38
http://www.edition38.com/forums/inde...owtopic=203338
I just scrounged this off a mk3 Vento and will be replacing the pump as mine's leaking a header tank a day from it! Not good when the weather's bad.
