Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: A/C & P/S delete & Serpentine Belt Thread
    Boronia VIC
    I thought I'd kick off a new thread to capture this info. There's a few little gems of wisdom dotted around the forums but it's hard to join all the dots at the moment.
    Here's my first contribution. What we're going to do here is in preparation to to put a 2.0L (2E motor) bottom end into a MK1.
    Most MK3s , the source of this motor, have power steering and air conditioning pumps, neither of which are usually required in a Mk 1. To do this they run a ribbed belt called the serpentine belt and a V belt. Both belts are driven off the Crankshaft. The serpentine belt drives the Alternator and the A/C compressor. The V Belt drives the Water Pump and the power steering pump.
    Now, to put a MK3 motor into a MK1 you could just use all the MK1 v belt pulleys and alternator. (The water pump may have to be changed too.). The advantage of keeping a serpentine belt setup are many.
    • Easy to Change Belt
    • 90 Amp alternator (instead of 35 or 50)
    • Automatic tensioner
    • More robust mounting mechanism for alternator
    • Etc
    So let's get started.
    Remove these bits.
    We're going to need one of these to drive the water pump. It's a water pump pulley off a VR6 Mk 3 Golf. I got this one from GAP http://www.germanautoparts.com/Volks.../Cooling/162/4
    First of all I'm looking for alignment of this pulley to the existing belt. As you can see in the next few shots it works out to bee a little too far inset. I'm going to need to make a spacer.
    Boronia VIC
    May as well remove the power steering pump and compressor at this point.
    Off with the belt
    and off with the a/c and p/s
    Now, back to that spacer, by the looks of things only about 2 - 3mm is required. Rather than get too complicated here I decided the easiest way to make the sapcer was the cut the centre out of the no longer required p/s pulley. This pulley has the same bolt pattern as the water pump and the same sized locating hole in the centre.
    (Professionals feel free to be horrified at my choice of tooling here)
    and dressing the edge with a more apropriate tool.
    Another test fit. Note here I'm also trying to work out how long the new belt has to be. More on that later.
    Offset looking good now. Could be about 1mm further offset to be perfectly central, but now the belt is squarely on the flat of the new pulley.
    Boronia VIC
    Time to go belt shopping!
    I cut the old belt and marked it at the extremes of the adjuster range to work out the minimum and maximum lengths it could be.
    Armed with this I stopped in at Autobarn (It was on my way when running some other errands) and thouroughly confused a 16 year old girl behind the counter. OK perhaps not the best place to ask.
    Repco was a few doors down the road and were a lot more switched on.
    Here's the missing part of the equation.
    Just so there's no doubt.
    6PK is the same profile as the original belt. The other part of the code is the length in mm. The original is 6PK1153 and the new one is 6PK1035, 118mm shorter.
    Working backwards from this, this belt is to suit the new Mini and the Lexus es300 should anyone need another way to reference the part number.
    GAP is showing this part 6K x 1033 http://www.germanautoparts.com/beta/...2/9310/5785607 which should do the trick, and for only US$14.24 rather than the AU$41 repco charged me.
    Their verison is 2mm shorter, which will work fine. It's a contitech part too, which is the same as OEM Golf.
    And here it is all fitted up.
    Hope this helps.
    Pete
    Last edited by Peter Jones; 24-08-2008 at 09:55 AM. Reason: Added detail on GAP belt
    Dec 2007
    Ermington, Sydney
    Even for someone like me with little knowledge in this field I understood everything Nice write-up Pete!
    Sep 2007
    wow... that's really clever. nice work!
    i just used a really crappy old A/C compressor as a tensioner.. so that's where all my power's going..?
    87' MK2 GTI
    13' MK7 TDI
    nice write up pete, its a shame it cant be worked to have more belt area on the waterpump, if that gets wet i think its gunna slip pretty bad. lets hope not tho.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    Nov 2005
    newcastle
    nice one pete... just did a serp setup on my mk1 engine too.. did it differently to you, but ill post up here when its finished to add to the knowledge base!
    love your work!
    mike
    TDI mk1 on the road!!
    you used a drill as a boring bar!!!! horrified doesnt even cover it
    nice work mate
    Boronia VIC
    Quote Originally Posted by GoLfMan View Post
    nice work mate
    The drill bit wasn't used for this job, it was there from something I did previously, it was the tool I was reffering to That one has a triangular tip which isn't so good for parting off. I changed to a parting off tool after this photo.
    Maybe you should bring me up to speed on the basics one day.
    Pete
    Camden, Sydney
    Nice write up Pete. I have the same setup in the Caddy and your accurate belt measuring could have saved me 3 trips to Bursons!
