May as well remove the power steering pump and compressor at this point.
Off with the belt
and off with the a/c and p/s
Now, back to that spacer, by the looks of things only about 2 - 3mm is required. Rather than get too complicated here I decided the easiest way to make the sapcer was the cut the centre out of the no longer required p/s pulley. This pulley has the same bolt pattern as the water pump and the same sized locating hole in the centre.
(Professionals feel free to be horrified at my choice of tooling here)
and dressing the edge with a more apropriate tool.
Another test fit. Note here I'm also trying to work out how long the new belt has to be. More on that later.
Offset looking good now. Could be about 1mm further offset to be perfectly central, but now the belt is squarely on the flat of the new pulley.
