Here's how it all prettied up, just before installation.
Yep, but I had to use shorter ones because I removed the V belt pulley.
Pete
Nice.
I'll be doing mine in situ, so fun fun fun!!!
I'f I'm using the MK3 waterpump/pulley (mine's shagged) would i need to make the spacer? logic says no, but reality says yes!
Are you leaving the cam cover off?
Hopefully it will all line up for you. I think the MK 3 1800 waterpump pulley has a different offset to the VR6 one I used. The MK 4 pulleys are different again.
I left the belt cover off, I couldn't be bothered trying to make the MK 3 one fit around the MK1 engine mount.
Pete
Just bumping this thread back up again, I've had a few questions of late about this stuff.
OZGTI I've soft deleted your reply as the picture links were broken. Let me know if you want to upload the pics again.
Pete
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Hey Pete,
I was thinking about the belt routing. Is the belt supposed to run on the ribs when it's on the water pump pulley? i thought smooth pulleys run the smooth side? I changed it on mine and I now get MORE heat through the heater core! So do i leave it your way with the ribs on the smooth pulley or run it the other way, smooth smooth?
Just a thought.
Yep, ribs are in contact with the pulley. VW themselves did it this way on the non A/C models.
I've done at least a dozen race sessions with this configuration and it's worked perfectly. Still using the same belt too
If you run it on the smooth side your water pump will be turning backwards.
7? MK1 Caddy
12 Amarok
Crap. Better put it back the other way then!
Five years on from the first post, just thought I'd say that the setup has run fine in all conditions on that belt.
It's done 1000's of km on the race track in all sorts of weather and been completely maintenance free.
7? MK1 Caddy
12 Amarok
Just read this and it's a cool little conversion. What's involved in grafting a Mk3 motor like this one into a Mk1? Is there a thread with an install documented in it that comes to mind?
