Results 21 to 30 of 40
Thread: A/C & P/S delete & Serpentine Belt Thread
  1. #21
    Oakleigh VIC
    Ahh, OK, I see what's going on.
    Some of the local MK 3 1800 CLs came without a/c and got that bracket but there's not many of those about. The a/c version above is far more common.
    Pete
  2. #22
    Feb 2009
    NSW
    Kinda, I think.
    The setup i've got has the alternator with a spring under it to tension the belt. How come yours has a seperate tensioner?
    From memory (it is almost 2am here) the alternator sits closer to the water pump than your setup ie lower.
  3. #23
    Feb 2009
    NSW
    Ahhh..
    oops, beat me to it!
    lol
  4. #24
    Oakleigh VIC
    See above
    Almost every MK3 model here came with airconditioning, so those brackets are like hen's teeth in these parts. I didn't realise you were posting from the UK.
    Pete
  5. #25
    Feb 2009
    NSW
    If you want, I can find out how much to ship a few of these to Oz? there's qite a few in the local scrappy.
  6. #26
    Oakleigh VIC
    Thanks, I'm sure a few would take you up on the offer but we'd need the alternator too and shipping rates on that sort of weight from the UK to Australia are notoriously expensive, hence the local innovations
    Be sure to pop up a few pics when you're done so we can see how your solution all fits together.
    Pete
  7. #27
    Aug 2006
    Melbourne VIC
    Mine has no AC
  8. #28
    Feb 2009
    NSW
    To remove the crank pulley, is it just the 4 allen head bolts or is it the HUUUGE bolt as well?
    Went to get a pulley from a scrapper and the pulley wouldn't come off!
  9. #29
    Oakleigh VIC
    I'm pretty sure it's just the 4 bolts. I'll take a look tonight.
    Pete
  10. #30
    Feb 2009
    NSW
    Cheers.
    Did you put your bolts back in?
