Page 9 of 9 FirstFirst ... 789
Results 81 to 85 of 85
Thread: building a 2L 8v for turbo?
  1. #81
    Oct 2006
    I dont believe 5k will cover it. There are always unforseeable things that will need replacing. While im putting my abf in ill be spending close to $600 on service items such as new clutch, new cv boots, new bushings, tie rod ends etc etc and this doesnt include my planned brake upgrade which ill budget another $600. Engineering costs another $400-1000 then dont forget insurance and rego. A standalone ecu will cost about $2100 inc installation or $1500 and u wire it in urself. That is practically 5k gone and u havent even bought the turbo, manifold, exhaust, piping, gaskets, head rebuilt? + labour costs. This is not cheap and i would not even consider cutting corners.
  2. #82
    Apr 2006
    Hobart,Tas
    $5K will not cover it, no way!!!
    Suspension, brakes, insurance???? ect. ect... The list goes on and on....
    If budget is no issue then spend up big!!!!
    If you are going to do it, do it once and do it properly.
    My 2 cents worth, Andrew
  3. #83
    Point Cook, Vic
    if we are talking on a car that has already had suspension upgrades a healthy engine and such. 5k is do-able if you are able to do a lot of the work yourself.
    to build a "complete" car takes more than 10k. but thats not whats in question.
  4. #84
    Oct 2005
    Nowra, NSW
    can the polo ecu handle boost? even just a small amount? surely getting a diesel manifold and turbo would be a very cost effective way to do it. Run it on 8psi or something with a small cooler or something.
  5. #85
    Jun 2007
    Eastern Suburbs Melbourne
    Quote Originally Posted by static1800 View Post
    tha plan is only for a small set up remember. SO things such as suspension and brakes aren't going to need massive amounts spent on them.
    And josh is looking at doing alot (really, all) of the work himself, or done free/cheap through work.
    and he's can get alot of things cheap, pipe, turbo, etc etc, as has been mentioned before a number of times!
    unfortunately no budget isn't an option, but I think the ECU will be the biggest challenge.
    i like volkswagens
