Originally Posted by
WABIT
u need to remember you can spend little money in achieving 8v turbo setup IF you know how to do things... i.e install, plumping, welding... and so on...
if you do NOT know these things or anyone close to you who does!! you can be up for big dollars....
i think i could make a 2k 8v turbo setup if i wanted to
all i would need is...
turbo manifold $800 or near
turbo and cooler 2nd hand $500-800 T03 of some sort running no more that 14-15psi and a mitsu evo cooler
piping and fittings $2-300
then there are costs u can avoid like welding a oil pickup line to the sump
welding pipes and mounting a cooler, installing turbo and just painting and finishing off
wabit
