Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 85
Thread: building a 2L 8v for turbo?
    Whats the budget? Seriously you come up with a figure and we'll spend it (theoretically). Just go 20v rather than pussy around on r&d
    Oct 2006
    That i agree with. When ur spending around 5k for a 8v turbo and a 20v turbo halfcut is around the 3-4k mark it is the more wiser option. Also the gearbox wont like the extra amount of torque since 020's arent really seen as strong boxes.
    Nov 2005
    Quote Originally Posted by peedman View Post
    U THINK 5K will be enough for a 20v turbo conversion in a mk1!!!
    try double that.... then add on all the nessecities you need to stop then turn and so on...
    y dont u think i didnt go 20v-t
    wabit
    Oct 2005
    Nowra, NSW
    You still need to be able to stop and steer with an 8v turbo.
    One thing i have seen guys in the states do is an aba turbo setup, which is a cross flow 8v head. Not sure of the availability over here though.
    Nov 2005
    but what about extra weight distribution.. its not the 8v it came with originally....
    nop crossflow 8v heads are not avalable here
    wabit
    Jan 2007
    People have been turboing 2l's for alot less than 6000 euro's. As mr Valver said, there literally are more parts you can poke a stick at, manifolds aren't the hardest things to get, and well the other parts like injectors and downpipes can either come from other cars or be made to fit by professionals. The ecu management seems to be the most difficult thing to obtain, a standalone obviously allows the owner to change almost any aspect of the car, yet isn't the cheapest thing around. Many tuning firms such as banhn brennan sell flashed chips for the stock ABA ecu's with certain fuel and psi conditions already programmed.
    I reckon you can get all the parts for 2000 grand or less, a heck of alot cheaper than buying a 1.8t, and then having to chip it and and spend more money on tuning to get it to a similar level of atwhp as that of a turbo'd 2.slow.
    Oct 2005
    Nowra, NSW
    actually, not sure if its aba's but you can get them. My parents mk4 is crossflow as was there beetle cab they had.
    Easiest way to do it may be get a turbo diesel setup, at least the mani and turbo will go straight on to an counterflow 8v head.
    engine management will be the tough part.
    Quote Originally Posted by WABIT View Post
    wabit
    Jan 2008
    Quote Originally Posted by Golf Houso View Post
    2000 grand is alot of money
    A turbo itself if a new item is over 1k. then manifolds and such, I think you'd be looking at more than 2k.
    150kw should be achieveable from a dohc 1.8l turbo motor. An extremely worked 1.8l SOHC turbo motor can see over 200kw atw. DOHC = more flow = more power.
    Feb 2007
    Quote Originally Posted by D3bb4 View Post
    Yeah itll cost more then 2K, exhaust alone is around that mark.
    A dohc 1.8l can make 150kw with no turbo i have been told, every easly too.
    By crossflow do you mean like the KR and the 2.0L in the mk3s, where the air goes in on one side and exhaust exits from the other?
    If so, then in a PVW issue a guy put a 2L head on a 1.8L bottom end, reduces heat aswell. Cant that be done?
    MK1 GLS 3door
    A4 B7 2.0T
    Nov 2005
    u need to remember you can spend little money in achieving 8v turbo setup IF you know how to do things... i.e install, plumping, welding... and so on...
    if you do NOT know these things or anyone close to you who does!! you can be up for big dollars....
    i think i could make a 2k 8v turbo setup if i wanted to
    all i would need is...
    turbo manifold $800 or near
    turbo and cooler 2nd hand $500-800 T03 of some sort running no more that 14-15psi and a mitsu evo cooler
    piping and fittings $2-300
    then there are costs u can avoid like welding a oil pickup line to the sump
    welding pipes and mounting a cooler, installing turbo and just painting and finishing off
    wabit
