Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Brake Boosters
  1. #21
    Mar 2006
    brisbane
    i got a set in bris for $20 from memory. ..brake pads look pretty good.
    they are camira rotors with the centres machined out to match golf size. havent trial fitted it all yet but i geustimate it will work.
    i didnt have to drill out the stud holes.
    this statesman booster ideas sounds promising....
    yeh, JE camira callipers and the rubber brake line looks like a match too
  2. #22
    Dec 2005
    Well I thought I would try the cheap route and get some camira calipers.
    Cost me 20 bucks from a wrecker. I think they are JD calipers, from about a 85 - 87 camira. The pads are double the size of the mk1 pads
    The caliper fits on, but hits the splash guard (bend/cut it so it fits). The mounting holes for the caliper are bigger (possibly 12mm) so you can either drill out the hub hole to fit bigger bolts or get a spacer made up to fit in the larger caliper holes.
    The problem I have is the disc is way to narrow. I doubt the pads would even touch the disc under full braking The pads may be a little worn. but they are a fair bit off... i doubt new ones would touch the disc.
    So, im guessing that mk1 gti discs are vented? which would make them thicker, hence the pads would touch.
    So do camira calipers only fit mk1 GTI discs or is there a way of making them fit a stnd mk1?
    cheers
    Lee
  3. #23
    Apr 2006
    Hobart,Tas
    mk1 Gti discs are vented. I fitted a T3 transporter booster to my Mk1 racecar with a 22m/m master cyl. However we fitted a Mk3 booster & master cylinder to a Mk1 with a bit of mucking around and that was perfect.
  4. #24
    May 2006
    byron bay area
    camira calipers
    ye i think that they would be to thin, i only had the vented discs on with those calipers
    i changed from the non vented when i put the camira calipers on
    next you will want to do the booster, you can get a 9' booster that will fit on with no mods needed, from a late model mk1 cabrio
    regards ian
  5. #25
    Camden, Sydney
    You can buy Mk1 GTI disks new, or use mk1, 2 or 3 vented disks or seat, or early audi 80, pre 1986.
  6. #26
    Dec 2005
    Quote Originally Posted by Golf Loon
    Wow... I saw mk2 vented discs in the DBA catalogue but thought they wouldnt fit unless you had different hubs ... Ill def fit the camira calipers soonish and post the outcome
Similar Threads
  1. Brake reservoir lid
    By gman in forum Mk3 Golf & Vento
    Last Post: 14-01-2007, 01:05 PM
  2. Audi S3 brake upgared (Caliper painting)
    By PoloGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 26-11-2006, 01:42 PM
  3. Golf Mk1 brake confusion
    By tassie_euro_mk1 in forum Mk1 Golf
    Last Post: 21-07-2006, 05:47 PM
  4. Brake lights
    By gotrice in forum Mk1 Golf
    Last Post: 20-01-2006, 10:33 AM
  5. A brake story...
    By imported_brackie in forum The Audi Quarter
    Last Post: 23-05-2005, 10:20 AM
