DNA Tuning (Australia)
Results 11 to 20 of 26
Thread: Brake Boosters
    imported_brackie Guest
    Mate with a SCAPYARD!!!
    h100vw.....You have a mate with a scrapyard??!! That must be like marrying a deaf and dumb nymphomaniac who's father owns a pub! We must talk re. diesel parts!
    Re: Mate with a SCAPYARD!!!
    Quote Originally Posted by brackie
    Sorry, to knock you back mate. He got out of the scrappy business a while ago. Bloody tree huggers and legislation. No more burning tyres to get 10 pence worth of steel out of them.
    He jumped through loads of hoops, he had everything on hard standing, no more than 2 cars high blah, blah. Each time he complied they came up with some more BS to keep him busy.
    He sells 4X4s now and just generally trades cars.
    Anyway what are you looking for? Anything in particular? Like I said in my PMs I have contacts in VWs round and about. Like Jim at www.awesomegti.com I can't promise discounts but they do ship worldwide all the time.
    Perth. WA
    Quote Originally Posted by Golf Loon
    This is a booster and master cylinder from an Audi 80, which is larger and stronger and so equal to putting a bigger booster from a Golf on. Obviously the rod has to be the same length and does have threads on, however, these were hard to remove without damaging the booster, so welding was easier. Thus you end up with a larger booster and master cylinder for a fraction of the cost of a Golf one from Brian. Last time I spoke to him, he was still promising bigger master cylinders and scirocco brake calipers, but not delivering. I know several people have had issues with dealing with him, and will not comment, but please also be a little restrained in your posts, as we do not want to read his name everywhere.
    People know where he is and thats cool, but he is not the only solution and the scene needs new input to grow.
    Have got a 9" booster from a LHD rocco here, it also uses the longer rod. Checked out with my brake rebuilder about stripping the booster so I could cut and machine a thread on the shorter shaft, but VW's OEM supplier in their wisdom have made the booster unserviceable, there are some internal tabs that have to be destroyed to open up the unit. Still looking for a suitable 9" unit for modding to fit to the Mk1's tho. Haver seen the unit on the Audi 80's also., but it looks to be a small bore ??
    Have been getting 10.1 caliper assemblies and bearing housings from the states. LMK if your wanting any .
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    sydney
    5 mniutes welding and the loons booster is ready to go simply as that,the damm thing has been rolling around in the back of my car for a week or two now
    yer and dont bag out brian ehh he is the man
    silva1 Guest
    brakes mk1
    hi there I fitted a 9inch booster tomy mk1 early tis year, what a big improvement. The booster is standard for the late model mk1 cabs, but still runs a 20mm master cylinder. 22mm mastercylinder is proving to be elusive at this stage , well one that fits anyway as I have brought one out of the the US & was to short in the shaft I have not been able to come up with the right one to fit the big booster. the booster made agreat improvement on its own. speaking of holdens ect, do you all know that holden camera calipers (je,jd) will fit directly onto mk1 hubs & fit the 239mm disc's perfect. They are a much bigger caliper
    We must be careful when cutting & pasting brake parts, as I am sure that none of it would ever get passed by an engineer
    that camira thing sounds great... itd be cheap parts too and greater stopping power
    Camden, Sydney
    Camira Calipers sounds good, cheap option and all that. Makes sense too, as it is really an Opel and so has the German Link. Plus there had to be something good to come off a Camira!
    PERTH
    that true, and what if it snaps surely u wouldnt want to see your dub flying up over a gutter or reacing for the handbrake, very important bit, or just cover the exposed bit of the booster box mount with a shiny bit of metal, surly no one will ever know.....
    or could cut it then get a tread tool and make a new thread good as new.
    the golf is not dead.
    take the front and back calipers and buy discs that bolt straight onto a mk1 at the back?? would that work... there has to be lots of wrecked camiras out there
    silva1 Guest
    mk1 brakes
    i don't know about the rear, but ht efront camera is an easey mod
    the camera caliper is made by girlock & made in australia
    you will have to redrill the holes in the hub from 10 to 12 mm, but that is it
    if you go any more than a 9 inch diameter booster it is rumored that it can foul the geat linkage
Similar Threads
  1. Brake reservoir lid
    By gman in forum Mk3 Golf & Vento
    Last Post: 14-01-2007, 01:05 PM
  2. Audi S3 brake upgared (Caliper painting)
    By PoloGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 26-11-2006, 01:42 PM
  3. Golf Mk1 brake confusion
    By tassie_euro_mk1 in forum Mk1 Golf
    Last Post: 21-07-2006, 05:47 PM
  4. Brake lights
    By gotrice in forum Mk1 Golf
    Last Post: 20-01-2006, 10:33 AM
  5. A brake story...
    By imported_brackie in forum The Audi Quarter
    Last Post: 23-05-2005, 10:20 AM
