DNA Tuning (Australia)
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Brake Boosters
    Camden, Sydney
    Brake Boosters
    Just thought I`d show you all what I`ve been up to today.
    I have a booster and master cylinder from a 1986 audi 80. It is much bigger in diameter than the golf one and the master cylinder is less bulky.
    It has a collar which connects it to the audi, with four bolts bolting it to the booster and three bolting it to the car. If I remove this collar, it should match up with the golf studs and fit up to the brake rods.
    As you can see, i got the collar off. Now to match up to the golf bracket.
    The audi booster has a longer arm, but it has a thread on at the same point as the golf one. Now if I can undo the rod, I can mount it up....
    Easier said than done. Won`t shift. I`ve soaked it in penatrating oil and will try again on the morrow...
    imported_brackie Guest
    See my brake post in Audi 100
    Brake post
    Camden, Sydney
    Got the end off the audi booster, but it is still too long. The rest of it all measures up. Am gonna get dubstaMk2 to cut and weld the two rods together.. Here are the two boosters. The Audi one is the larger.
    sydney/ cessnock
    to much effort
    boys boys boys can i let u in on a little scret
    i run a nine inch booster in my project golf for over a year gives a big improvement to braking performance the only thing is u have to be careful about the length of that rod very important can affect pedal height and travel. the other important thing is if u have up graded your brakes to much bigger u also need to up grade to a biggger master cylnder 22mm. i dont know what the booster came from but can tell u where to get it. GTI imports 96531114 im gonna put a post up 4 him
    owned a number of mk1 golfs have a collection of spare parts project golf is a 78 2 door
    Camden, Sydney
    This is a booster and master cylinder from an Audi 80, which is larger and stronger and so equal to putting a bigger booster from a Golf on. Obviously the rod has to be the same length and does have threads on, however, these were hard to remove without damaging the booster, so welding was easier. Thus you end up with a larger booster and master cylinder for a fraction of the cost of a Golf one from Brian. Last time I spoke to him, he was still promising bigger master cylinders and scirocco brake calipers, but not delivering. I know several people have had issues with dealing with him, and will not comment, but please also be a little restrained in your posts, as we do not want to read his name everywhere.
    People know where he is and thats cool, but he is not the only solution and the scene needs new input to grow.
    Re: to much effort
    Quote Originally Posted by sydneymk1
    Could this be the source of my problems with my Audi 100 brakes?? Is there a spacer in there that's dropped out or something?
    See my earlier posts in Audi "Brake Story".
    Re: to much effort
    I've just sourced a 22mm master cylinder from the states for cheap. I've heard a bigger servo is also needed to improve braking?
    Those rod can be really, really tight. Having done this to many MK1s in my time. I have always managed to undo them. Sometimes a bit of 'heat' helped matters.
    I don't think cutting and welding is the best way to go.
    When you get the fork off you just need to get the length right by cutting of the correct amount of threads. I just measured from the mounting face of the original to the end of the fork.
    Apologies if I am stating the obvious to anyone.
    On another note, I fitted a servo off a Vauxhall Senator to my wifes mk1 GTI. This was a marvelous conversion. The assistance was incredible. It would out brake my 270mm disc and 22mm master cylinder and mk2 servo setup easily.
    Everything else was std on the car. You only got 2 good stops out of it before it overheated the pads. That could be sorted though. I always forgot about the brakes when driving it, nearly butting the screen and pulling up short at every junction.
    Camden, Sydney
    I have unthreaded them before. This one had a really long arm on it, which did not have thread going down the rod far enough. Its welded and functional now, pics soon.
    What year vauxhaul senator was it? and did it bolt straight on?
    In Australia the vauxhal senator is the holden commodore and there are heaps of em!
    Quote Originally Posted by Golf Loon
    I thought there would be an Australian equivalent. It would have been a late 80s one. I just found the servo in a mates scrapyard. The bolt pattern was the same, I took a chnace that it would fit. Just had to get the rod the right length and 'warm up' the bottom of the expansion tank and jam it in. The bonnet would shut otherwise
Similar Threads
  1. Brake reservoir lid
    By gman in forum Mk3 Golf & Vento
    Last Post: 14-01-2007, 01:05 PM
  2. Audi S3 brake upgared (Caliper painting)
    By PoloGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 26-11-2006, 01:42 PM
  3. Golf Mk1 brake confusion
    By tassie_euro_mk1 in forum Mk1 Golf
    Last Post: 21-07-2006, 05:47 PM
  4. Brake lights
    By gotrice in forum Mk1 Golf
    Last Post: 20-01-2006, 10:33 AM
  5. A brake story...
    By imported_brackie in forum The Audi Quarter
    Last Post: 23-05-2005, 10:20 AM
