Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Bluefin Stage 2 Update
    Jan 2012
    yup, i had a mk6 golf gti stage 2 map on my 2012 octavia TSI
    same engine, same ecu. slight stock map change to lower the power of the skoda. ultimately, identical
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by zei20t View Post
    Thanks. So just clarifying. You had the bluefin stage 2?
    Havent heard sweet FA back from bluefin yet either.
    Jan 2012
    email them again. i never had issues with contact with them. its possible they missed it
    there is also the aussie rep Peter James to make contact with. his details are on the superchips website. great guy to deal with!
    i did have an issue with the tune. turns out the APR intake i had on the car had a slightly different pipe diameter to the AFM and it caused a misfire/hesitation. stock airbox fixed it right up!
    Oct 2009
    Mitchelton, Qld
    Finally got a reply back from Superchips. Here's what they said:
    "The data you are looking at is actually for two totally different engines with different ECU’s.
    Your Octavia should have the later engine with a Bosch MED17 ECU so it will respond in a similar manner to the Golf 6 GTI in the 2nd link you have used. The 1st link applies to earlier cars with the older engines & ME9 ECU."
    FYI I have a 2012 TSI vRS.
    Jan 2012
    that sounds correct.
