Results 1 to 10 of 14
Thread: BLUEFIN Killed ECU??
    Apr 2009
    North Ryde, Sydney, NSW
    Hi all
    My brother has a MV5 GOlf TDI which has been running a bluefin tune for ages.
    One day he was unable to start the car.. thought it was a fuel pump.
    Took it to VW and they cleared and updated the ECU .. car started fine again.. they said it was a batch of bad fuel
    Yesterday after trying to reflash with Bluefin again. BUT. it failed halfway!.the car didn't start! Similar fashion to before..
    would crank and crank but car woundn't start
    Tried to use the bluefin to restore back to factory mapping but it would come up with E001 error unable to READ the ECU or something..
    Its now at a mechics who said they have spent a whole day on it but can't get the ECU to hold the flash.
    Do I take it back to VW? Can they do something this mechanic cant?
    Is there a chance the ECU is dead ?
    What sort of damage bill expected??
    Will Superchips Bluefin warrant or pay the repair bills?
    2012 MY12 Octavia RS Wagon
    DSG, Black, Sunroof, Leather, HIDs, Michelin PS3.
    VW can probably fix it again.
    They will have loaded the latest software and the ECU may have been a bit behind. So when you flashed it with the stored tune, it has had a conflict, for want of a better word.
    I reckon you need to have VW flash it again and then read that file with the Bluefin and have another tune written. Then flash that one in.
    I don't know how you go about sorting that with Superchips though. I'd email to find out.
    Apr 2009
    Thanks for that h100vw
    Thats interesting... will see how we go tomorrow and will post back.
    But yes that makes sense.. flashing with the OLD bluefin mapping on newer VW ECU software could have screwed things up.
    Quote Originally Posted by li21 View Post
    Potentially.
    We definitely don't flash older versions of tunes over new standard files.
    You should get in touch with Superchips for advice.
    Aug 2007
    Ive replaced a couple of Mk5 ( early ones) Engine Ecu,s that has check sum errors, tuned or not tuned. both the ones i have seen were AXX engines.
    Alba European
    Quote Originally Posted by Jmac View Post
    Any diesel issues Jimmy?
    Apr 2009
    Okay so Superchips reckon I need a over ride code... problem is it will be 10pm over there when i get the the mechnics in the morning to even attempt it.. (needs to be done on the spot)
    Are there any Bluefin agents here that could help us out with the override?
    thanks
    Point Cook, Vic
    speak to mark at recode
    Contact Info
    FOLLOW US ON FACEBOOK
    Quote Originally Posted by Tim View Post
    Contact Info
    There's something weird going on here because normally an updated ECU wont let you flash anything on it because the flash counter has been incremented( and a couple of other things). The thing is we don't know if the car was updated by VW or not either so its sort of guessing as to whats really going on.
    It could for example be the original HW and SW file version but a bad flash due to voltage drop at some point, although the bluefins seem to handle lower voltages than any other device and the diesels are quick to flash regardless but its still a possibility. It could also be a hardware failure within the ECU not unlike the MED9 eeprom data issue that was affecting the MK5 gti's and even some golf R's. You can update this and fix it seemingly but it can come back again _ I dont think it would be this though because you were able to write to it
    Let me see what the SC guys have to say and I'll see if we can sort something out as I'd just be guessing at this stage might be a simple fix
    Aug 2007
    Na Gav, so far only mk5 gtis all early ones so far, all been running new ecu,s for a while now with no drama.
    Alba European
