Results 1 to 4 of 4
Thread: Bigger Turbo
    Mar 2009
    Bigger Turbo
    Has anyone changed turbo on the TSI engine? i think it is running the K03 has anyone changed bolted new turbo straight on? and what turbo did you change to.
    Nov 2009
    Which TSI engine are you referring to? There are a few of them...
    If you're referring to the EA888 2.0 TSI as fitted to the Mk6 Golf GTI (and quite a few others), a few members have gone stage 3 with a bigger turbo. Sammy125TDI comes to mind. See this thread:
    http://www.vwwatercooled.org.au/foru...ild-62977.html
    Mar 2009
    How do i know which TSI? All know it 08 passat TSI 2.0 Tiptronic gear box. Thanks for info.
    Given that you have the Tiptronic automatic, i would suggest chatting to APR about whether these gearboxes are up to the task of significant increases in power and torque before you go much further.
    For instance, i know with the CVT gearbox equipped Audi A4 2.0TSI, APR wont go further than a stage 1 tune because the CVT gearbox is quite fragile and are not manufactured for high powered applications.
