![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
Martin
Another very cost effective option is QFM pads - GSL sell them
HPX series for high performance or A1RM for frequent/hard track work
These work great and are one of the cheapest performance pad you can get
I run the A1RMs on road between track days and they work alright on the road even from cold, although I don't drive aggressively in traffic. The big thing is to bed them in properly else they squeal mightily.
According to Greg at GSL Rallysport, the HPX pads are on par with the Remsa ones but priced a bit higher which is why he recommends the Remsa pads for normal, aggressive road use.
The DBA slotted rotors make a funny whirring sound when you brake hard.
Resident grumpy old fart
