![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
seangti
I'm on my second set of remsa's, many of the polo guys are running them (perhaps cos that's the main place I frequent). They are a very good pad, and a very good price. They are a higher temp pad to OEM, so coming from a stock pad you may notice a lack of initial bite when you first touch the brakes of the morning, but that's a minimal sacrifice, and they hold up well under high temp applications. Regarding brake dust, from recollection that are marginally better than OEM, though others have had better results saying much less brake dust.
For me, both sets of pads have had extensive track use once bed in so I think I'm using them beyond their design tolerances, a corner a Qld raceway on back straight has me going from ~175kmh to 60kmh at the hairpin apex within 120m, so it's highly committed braking. Other tracks don't require the same level of retarding so the brakes are fine, e.g. lakeside. In saying that, they are fine for track days if not punching sustained highly committed laps, they'll with stand it, but brake feel over time deteriorates and wrecks your rotors. They haven't failed me and rotor wear is fine.
+1 ![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
also, Jason Statham (Machine) in his white Golf R uses Remsa pads.
MINI Cooper S Clubman - FWD
