DNA Tuning (Australia)
Results 1 to 10 of 13
Thread: beading on intercooler pipes
    Aug 2006
    where can i get this done in syd?
    or does any1 have DIY to doin it urself or sumthing similar?
    Perth. WA
    try any sheet metal shop. Need a sheet metal bead roller.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jun 2006
    Orange NSW
    Are you talking about the weld bead from tig welding the pipe work together?
    Jan 2006
    I think he might be referring to the double flair to keep the hose from popping off. If so I'm interested to hear of backyard methods for doing this too. I haven't see the proper tool but I reckon something could be rigged up out of a set of vice-grips and a roller.
    Oakleigh VIC
    Gosford Central Coast NSW
    AHHH - i hear DIY mentioned and i'll offer my method (so far proven on 2" pipe to 22psi.... oh, but no-one will have stainless intake pipe but me i'm thinking... hmm, well anyway...
    turn your MIG down to a low setting and zap a few knobs around the perifery of the pipe end (about 8 is good). this means no sharp edges and the pipes cant slip off since the hoseclamp would have to actaully stretch to get over the knobbies once tight... make them 1-2mm high is all you need.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
