Results 1 to 10 of 13
Thread: beading on intercooler pipes
    Aug 2006
    where can i get this done in syd?
    or does any1 have DIY to doin it urself or sumthing similar?
    Perth. WA
    try any sheet metal shop. Need a sheet metal bead roller.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Jun 2006
    Orange NSW
    Are you talking about the weld bead from tig welding the pipe work together?
    Jan 2006
    I think he might be referring to the double flair to keep the hose from popping off. If so I'm interested to hear of backyard methods for doing this too. I haven't see the proper tool but I reckon something could be rigged up out of a set of vice-grips and a roller.
    Oakleigh VIC
    Gosford Central Coast NSW
    AHHH - i hear DIY mentioned and i'll offer my method (so far proven on 2" pipe to 22psi.... oh, but no-one will have stainless intake pipe but me i'm thinking... hmm, well anyway...
    turn your MIG down to a low setting and zap a few knobs around the perifery of the pipe end (about 8 is good). this means no sharp edges and the pipes cant slip off since the hoseclamp would have to actaully stretch to get over the knobbies once tight... make them 1-2mm high is all you need.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Jan 2006
    That would work fine. When I had access to a lathe I set up a roller from a house sliding door into the tool holder and just wound it against the inside of the pipe until it formed an indent - a bit dodgy but it worked!
    I was thinking a set of vice-grips with a roller welded perpendicular to the end of one of the jaws and something welded onto the end of the other jaw to help form the bead and just roll that around the pipe continually winding the vice grips tighter like a pipe cutter.
    other thing you can do (aluminium pipe is soft) is whack it over the end of an anvil (if you have access to one) on the mandrel end to flare the pipe a little bit.....
    i guess i'm lucky having acess to so much good equipment at work (big hydraulic presses, etc)
    '99 A4 Quattro 1.8T
    Jun 2006
    Orange NSW
    Hehe, like me!
    You can also use a big steel ball or something similar, sit it in the end and whack it with a hammer to flare the end.
    Jun 2006
    Orange NSW
    I have a lot of stainless pipe work under the hood aswell!
    Iscar and Valenite manufacture tooling for internal and external roll forming on lathes. But its easier to simply tig weld a bead around the end of the pipe...
