My APR Stage 1 got its mojo back.
Set off on a 200km drive to MELB early this morning, heading to Volkspower to look at my ECU tune that was not working. ON the way I noticed it was miraculously working again. Climbing all the long hills nicely in 7th gear which it had ot done for months. As it was 0600 in the middle of nowhere I did a quick 0-100 run with VCDs and it did a 6.9 sec run straight up!! Equal to the best time I have ever got last year and the Axle tramp felt like it was going to chuck the engine out of the car. Way way more tramp than I'd seen when I tested a few days ago. So it is definitely working again. Hooray. So I didn't even end up going to Volkspower because all was good again.
It seems that sometimes, even though the correct program is activated by way of the cruise control and the correct sequence is flashed back at you it may not actually function properly. Even after several thousand kms. So good idea to get it working and not to switch programs I suppose.
A Long bow I know, but two days ago I filled up with a tank of BP optimax 98, when for the past few months I have been using Shell Ultimate 98. Unlikely all the shell fuel is crud though over a period of 3 months. But maybe something in what you said thezoneR32.
Anyway main thing is it is fixed again and I am happy again.
