DNA Tuning (Australia)
Page 18 of 51 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 506
Thread: APR ECU Upgrade MK6 Golf - Customer perspective
  1. #171
    Apr 2010
    If you take the car back to the ACR place and get them to redo the ECU, do you think you'll get your power back? Just curious: Although you say it's down on power, is it still more powerful than stock?
  2. #172
    Aug 2009
    Melbourne, Vic
    Good Points Ryan.
    Done that already. From what I understand, a VW ECU reflash such as SC24S4 overwrites and effectively removes the stage 1 tune. So you have to take it back to APR and get their tune reloaded afterwards. I did that straight away.
    I know it is far more complex than this with curves and so on. But in a a simplistic sense, if a tune hypothetically increases power and torque by say 10% from standard, then because the standard MAY have been reduced by SC24S4, could not the net effect be reduction in the maximum torque available? ie is it an absolute or relative effect.
    Dunno. A bit perhaps. The glaring difference previously was its ability to hold gears much longer as torque requirement increased.
    This was a difference that was clearly demonstrable, whereas all the seat of the pants stuff is subjective. Cant see that difference any more.
    Now you have got me thinking.. Wonder if it is possible for APR to have somehow mucked up the ECU tune so I have stock in both positions?
    I think I had better give them a tingle tomorrow.
  3. #173
    Apr 2010
    No worries, I'm still thinking of getting Stage 1 applied next year after my first service and of course want to know if it's still worth it by the time I get around to it. Keep us posted.
  4. #174
    Apr 2010
    Nedlands, WA
    Quote Originally Posted by logger View Post
    Didn't you post acceleration measurements with the APR tune enabled/disabled before and after the service campaign? Regardless, I would've thought you could very easily test low-RPM torque with the tune vs stock, using your VAG-COM to measure acceleration.
    I keep coming very close to calling up the local APR dealer because while I'm quite satisfied with the 118TSI's performance, I miss the shove to the back of your seat that you get in e.g. a diesel Golf or my old XR5 Focus. I'm not really sure whether it would help though - hard to say whether the TSI feels subjectively slow because of its lack of low-end torque, because the DSG box is so much smoother than the manuals I'm used to, or just because it's so quiet.
    Golf 118 TSI DSG, white with sports pack.
  5. #175
    Apr 2010
    The only problem of making the car faster is that you spend less time enjoying spirited acceleration. I guess that's one of life's Catch 22 situations for you. I've adopted a slightly different foot position to avoid the pause when accelerating, but I feel that it takes a tad longer to switch back to the brake pedal if needed, so I don't use it in peak hour. I reckon a new pair of shoes might help too, my current work ones a pain to drive in.
  6. #176
    There is no real change in the performance calibration of the updated VW file, the "safety" stuff that has been modified by VW should not effect performance - if it did, it would effect the standard performance (not reported by anyone that I know of).
    Imagine Volkswagen sending a letter & new badges out to customers:
    Sorry, your car is no longer a 118tsi, its now a 112tsi .......................
  7. #177
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by cameronp View Post
    The acceleration measurements I did were way back before I got the service campaign. But good idea. Am in in position to test and compare it again in the next few days.
    That being the case, could it be my stage 1 tune was not reloaded correctly after the service campaign. Switching all seems to work though.
    Should I expect to be seeing the same max manifold pressure in both modes? Because a quick test shows it currently peaks at 2360mb in both stage1 and stock.
  8. #178
    If the switching is there, then the program is loaded 100% - the performance calibration has not changed a single bit between revisions. Don't forget if you are going to be data logging on the road, after switching you should allow a good period of time to allow the adaptation to catch up. do a TBA to clear your fuel trims as well!
  9. #179
    Mar 2009
    Melb
    I recall Superchips telling me that SC24S4 did limit the max torque. Took them a couple of months to send me a new program.
    ted, maybe we should meet up to compare tunes.
  10. #180
    Aug 2009
    Melbourne, Vic
    I did some 0-100kph testing with VagCom today. Seems to confirm that my APR ECU tune has lost its mojo
    14 runs back and forth on same track and no marked difference between stock and APR. Performs like a stock 118tsi in both programs.
    Program 2
    APR STAGE 1 ACTIVE - So the car should be faster that stock right? Always has been in the past when I tested it. It has been in Stage 1 and driven for about 250km since ECU programs were last switched.
    8.2
    8.3
    8.2
    8.5
    8.3
    These times are what you might expect from a stock standard car with no tune. Not what you should see with the tune active
    Program 1
    STOCK program active and and TBA performed. (Although not driven more than about 3 km since previous runs so fuel trims may not have adapted. So I am happy for you to discount these runs.
    8.3
    8.2
    8.2
    7.9
    Still in Stock tune, but now 6 hours later, after driving 80km with stock tune active to ensure it has adapted fuel trims. Car allowed to sit for about 4 hours in middle of the 80km drive. Restarted and returned to same test track.
    7.9
    8.0
    8.1
    7.9
    7.9
    So these times in stock mode were faster than achieved earlier with the Stage 1 tune active!!! Granted it was 6 hours later and some environmental factor may have changed. But the point is, these should have been slower not faster.
    You will recall from earlier in this thread - I had in the past achieved 6.9 sec with the APR Stage 1 and routuinely done it in the low 7s. The improvement used to be just under 1 sec. But more importantly there was a difference. Now I see no difference
    Is it possible that stock tune is getting selected by both programs? Sure seems that way.
    Quote Originally Posted by mr gee View Post
    I recall Superchips telling me that SC24S4 did limit the max torque...... maybe we should meet up to compare tunes.
    Yeah we could do that, but you would flog the pants off me
