Page 4 of 51 FirstFirst ... 2345614 ... LastLast
Results 31 to 40 of 506
Thread: APR ECU Upgrade MK6 Golf - Customer perspective
  1. #31
    Sep 2009
    thanks for those figures. no one can complain about the actual figures posted
    very promising and definitely aiding in my decision process
    Jetta MK6 147TSI DSG Reflex Silver
    Pondering: too many to list...
  2. #32
    Aug 2009
    Melbourne, Vic
    Trying to compare Top Speed
    Did some more testing this morning. My aim was to find terminal velocity in each tune, however I couldn't quite get there as my test track is too short. At 2km with a 1.6km (1mile) straightaway I was still accelerating when I had to back off. I reckon you probably need about 3km to get it wound fully out.
    Best I could get to was 215kph indicated or 203kph true with the Tune. Again using the DSG's "S" position and WOT. Measured with Vag-Com, so speed and data should be accurate.
    Two runs over same length of track, one with Stock tune and one with APR Stage 1. Limited access to the track meant only a single run in each tune I am afraid. Basically I entered the straight away at ~ 110kph then pegging it to the floor. Here is a graph showing from 130kph upwards. Three vertical white lines, one on each graph are snapshot points, with corresponding data at the bottom.
    Things to Note:
    First snap is at common time stamp (24sec), speed (141kph) and revs (6000) so differences can be read from here on.
    Eng % Loads differ markedly. Never above 150% in stock and up to 175% with the tune!
    Never got into 6th gear in stock. Wasnt going quick enough.
    Second snap shot point at 40secs is interesting. This is where APR Stage 1 tune reached Stock tunes eventual max speed in the test. A full 8 seconds earlier which is fairly telling. To put it another way, Stock took 24sec to go from 141kph to 192kph, APR stage 1 did it in 16 sec or in 2/3 of the time! 33% Quicker in this specific area!!
    Third snap as where I ran out of test track and had to back off. This shows max speed reached for each tune. I really wish I had the extra KM to see max speed. OH well - Good fun none the less.
  3. #33
    Sep 2009
    awesome work logger!
  4. #34
    Aug 2009
    Melbourne, Vic
    Glad you like it. The more info there is out there the better I reckon. It is also sorta fun checking it all out.
  5. #35
    May 2009
    North East Victoria
    Logger, was ur test track Winton? If it is PM me next time you visit as I live ard the corner and wouldn't mind checking ur car out.
    I notice you do not have sports pack on ur TSI. Do you find the body roll excessive? I thought it did but then again I felt the sports pack too firm and rather like the comfort of standard suspension.
  6. #36
    Sep 2009
    Melbourne - Australia
    logger thank you for this information very valuable. I hope you get a chance to test the max speed soon.
  7. #37
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by soogs View Post
    Unfortunately not. SE Vic.
    No, not at all. I find I can give it plenty of stick through the bends without too much roll. But I will clarify this by saying I am not an expert in these matters. When I considered the sports pack, I was put off by; the cost, the loss of ride comfort and a fear that there would be more tire noise with the lower profile rubber. I could not reconcile these negatives with the benefits. If I was 20 years younger I probably could.
    Quote Originally Posted by oileoi View Post
    Considered, going back to the same track and being more daring, but on balance I think it would be a waste. Need more distance to wind this baby up.
  8. #38
    Aug 2009
    Melbourne, Vic
    I see APR are doing a sale. Might be an opportune time for anyone who has been holding off on the stage 1 due price. An early Xmas present...
  9. #39
    Apr 2008
    Results from the dyno day:
    (Mine is a MkV 1.4)
  10. #40
    Feb 2009
    Quote Originally Posted by GTom View Post
    (Mine is a MkV 1.4)
    Would be awesome if someone with a stock GTI posted results from the same dyno, to see how closely the tune gets you to GTI performance..
    also has anyone tried any tunes other than apr for the 1.4tsi?...
    not long ago I saw a bluefin superchips for the 1.4tsi on special for 800aud.
    Cheers,
    |Golf Mk VI 118TSI|Manual|Pearl Black|Sports Pack|Sunroof|F & R Parking Sensors|Park Assist|RVC|Alarm|RNS-510|VW Premium Bluetooth|MDI| http://www.hoodiaslimming.com.au - 100% Pure, 100% Organic
