Page 37 of 51 FirstFirst ... 27353637383947 ... LastLast
Results 361 to 370 of 506
Thread: APR ECU Upgrade MK6 Golf - Customer perspective
  1. #361
    Dec 2009
    Kew, VIC
    3 laptops, 3 x hex USB + Can cables, connect directly to the can wires. There is no limitation on the can bus talking to different modules, the limitation is 1 laptop / 1 USB connection / 1 VCDS cable per laptop.
    So if you connected VCDS cable to hub and hub to 3 laptops with VCDS program, that wouldn't work?
  2. #362
    Apr 2010
    There are USB splitters, to share a device with 2 PC's (but only one at a time, not simultaneously).
  3. #363
    Nov 2009
    Thought as much, I'll leave that stuff to the experts
  4. #364
    Quote Originally Posted by Idle View Post
    Nope, the cable is a dongle in itself so I cant imagine that working (nor can I imagine anyone trying to sync the data!) - all hypothetical really.
  5. #365
    Nov 2009
    Not to mention if it was possible to log multiple sources with a single cable, I'm sure the VCDS software would be updated to allow such.
  6. #366
    Correct, I'me sure Uwe would love to have the ability to do that!
  7. #367
    Aug 2009
    Melbourne, Vic
    Pretty sure I worked out why my 98 Ron tune spontaneously stopped working without me switching anything. At some point I have had a fault in my Ignition switch that spat "Electrical Fault in Circuit - Intermittent" messages on four separate terminals. When this occurred it appears to have interrupted power to the ENG ECU. Cutting the power to the ECU means the the APR software will default to program 1 when power returns. In a standard installation this is Stock mode.
    So all I needed to do was re select the 98Ron program in position 2 and all is fine and beaut again. So a power interruption in the car resulted in the ECU reverting back to the stock program. While I was aware the 98Ron tune performance gains were missing and the car was driving like stock, I was not prepared to try switching it back on. I wanted there to be no doubt that I had not meddled with the switching in any way to cause the fault.
    So nothing wrong with the APR Tune. The cause appears to be a transient fault in my car that had the undesired side effect of deselecting the tune. Happy camper again.
  8. #368
    Apr 2010
    Nice to hear. I wish I could set 98 RON as the default program.
  9. #369
    Feb 2009
    Sydney, Australia
    So Ryan_R, do you have a VCDS cable - could it be you have the same ignition issue that logger has?
  10. #370
    Apr 2010
    I do, but I seem to be switching to Program 2 nearly every time I start the car now, with unpredictable results when I lean on the accelerator.
    From my limited experience, it seems the best way to get the most from the car is to just drive it in whatever mode it is for 20 minutes to allow the engine to warm up, then when you get to a road where you want a bit of performance, pull over, park, switch to Program 2, and head off again.
    I'll run a fault check when I get a chance.
