I did some 0-100kph testing with VagCom today. Seems to confirm that my APR ECU tune has lost its mojo
14 runs back and forth on same track and no marked difference between stock and APR. Performs like a stock 118tsi in both programs.
Program 2
APR STAGE 1 ACTIVE - So the car should be faster that stock right? Always has been in the past when I tested it. It has been in Stage 1 and driven for about 250km since ECU programs were last switched.
8.2
8.3
8.2
8.5
8.3 These times are what you might expect from a stock standard car with no tune. Not what you should see with the tune active
Program 1
STOCK program active and and
TBA performed. (Although not driven more than about 3 km since previous runs so fuel trims may not have adapted. So I am happy for you to discount these runs.
8.3
8.2
8.2
7.9
Still in Stock tune, but now 6 hours later, after driving 80km with stock tune active to ensure it has adapted fuel trims. Car allowed to sit for about 4 hours in middle of the 80km drive. Restarted and returned to same test track.
7.9
8.0
8.1
7.9
7.9
So these times in stock mode were faster than achieved earlier with the Stage 1 tune active!!! Granted it was 6 hours later and some environmental factor may have changed. But the point is, these should have been slower not faster.
You will recall from earlier in this thread - I had in the past achieved 6.9 sec with the APR Stage 1 and routuinely done it in the low 7s. The improvement used to be just under 1 sec. But more importantly there was a difference. Now I see no difference
Is it possible that stock tune is getting selected by both programs? Sure seems that way.
Yeah we could do that, but you would flog the pants off me
