No fuel pump required to tune your car.
If you purchase the revised "high pressure fuel pump" that is a supersession direct from Volkswagen, you will get more power & torque.
If you pull your engine cover off your car and look carefully you can get the VW part number off it & we can let you know if it's early or late.
Heat Soak?
Summers here. Anything you can do to reduce intake temps (like an intercooler) will help maintain your power.
- You may not post replies
- You may not edit your posts
Forum Rules
