DNA Tuning (Australia)
Results 1 to 5 of 5
Thread: Apparent Boost leak on Mkv gti. Anything unseen to think about ?
    Mar 2012
    Sydney NSW
    Hey everyone. I have a mkv gti , currently in the process of back and forth street tuning with Mr Gav of custom tune. Car is dead standard apart from a downpipe and frontal pcv fix ( inlet manifold plugged and front plate with a tube loop).
    Can I note the car is not tuned yet , currently in testing phase. Uploaded a beginner map but no advance in timing.
    Car is sluggish in most situations and occasionally logs the below. Once cleared it doesn't come back until a good amount of thrashing
    16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached.
    I've checked the DV - it's a new revision D part. Installed correctly, there is a very slight oil weep from the inlet side of the standard intercooler but apart from that I can't find or hear anything else obvious.
    Anything else I can have alook at while I install a S3 intercooler later this week ?
    Is it possible that the frontal loop I have run is compressing or blocking under WOT ?
    Mar 2012
    Sydney NSW
    PS Gav @ customtune is a fantastic bloke and doing everything he can even though we currently are dealing with a long distance relationship ;0)
    Have you had a good look on Google for other MK5 GTI's that have had the same issue?
    https://www.google.com.au/#hl=en&tbo...w=1366&bih=684
    Apr 2006
    VW Race HQ - Sydney
    My guess is 3 things :
    Turbo is kaput
    Intake is blocked
    Cat is blocked
    Bug_racer supports the rebellion of the euro revolution
    Quote Originally Posted by bennjamin View Post
    so someone has modified the map to do what ??? was it doing this before the modified file went on ??
