Why do you need to remove it?
Heat might work but they are in there funking tight. I have never removed one myself in nearly 20 years of VW ownership. Only when they have undone themselves on G60s and 16Vs.
Certainly when you replace it, I can recommend that you use the hex bolt and washer from a MK1 DX engine. The stretch bolts just don't seem to cut it as replacements.
- You may not post replies
- You may not edit your posts
Forum Rules
